Thanks. Do you happen to remember the name of the flexible hi temp sealant?
Also, great idea on the vent, I need to do that for my fog. If you can recall where you purchase them, that would be awesome!
had no idea... if you go to the root of the page, you will see his email address and you can email him.
this was done a while back.. when he was freshman in college.
i just paid the guy!!!
Looking to get this help for some retro on my 2GS.
available at any hardware. probably can use any type of epoxy and/or silicone. same stuff used on the voicecoils of woofers.
Yes it will work, but when you purchase the bracket, you must get the one for the auto-leveling housings. It has a different size 'square' slot on the bottom for the leveler. Also, the part that you trim behind the turn signal will need to be cut a bit more to accommodate the movement of the projector shroud. Best way to do this is install the empty housing with the projectors installed, slide the chrome bezel on and as you get them to level, look where its hitting on the bezel remove and shave a little off, reinstall check the clearance again and uninstall then remove a little etc until its perfect. Its a bit tedious, but well worth it
