Foglight/ Turning signal problem!
Hey guys. So my 3000k HID's came in for my foglights earlier today so i installed them and decided to take it for a test drive and see how everything was. First of all these definately help the overall light output, AND they look really good! Anyways everything was going good until i used the turning signal. It seems that whenever i tap or fully engage the turn signal to the left or right my foglights shut off then turn back on again. This is very annoying and i know its bad for the ballasts as well. But if i put the foglight turn **** halfway between on and off then it doesnt do it?
The only problem with that is after the turn signal clicks back the **** normally goes back to the ON position and the problem resurfaces.
Does anybody know what the problem could be? This is getting very annoying and almost disapointing because the car looks soo good with it's new HID setup. Any help would be appreciated! Already searched, came up with nothing...
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Sorry for the lack of info. Yes it is a 35w plug and play kit. Basically the install was VERY easy took me about ten minutes. Lights turned on fine, then if i even gently touch the turn signal the fogs shut off/ flicker then turn right back on.
Step by step:
Removed two screws for foglight (need to get hex screws)
Unplugged the harness from fog assembly
Untwisted the stock bulb.
Installed the HID bulb and harness.
Hooked the HID bulb harness to the ballast.
Hooked the harness into the stock light harness.
Used double sided tape and mounted the ballast on the engine cover so it wouldnt fall off.
Reinstalled the foglight.
Repeated for both sides.
Here is a link to the actual kit.
http://cgi.ebay.com/ebaymotors/ws/eB...ht_3475wt_1141
Bulb size 9006.
I can undo the kit and reinstall the stock bulbs to see if it still does the same thing? And i can take pics of the wiring to see if everything is in the right place. But wouldnt it not turn on if the wiring was incorrect?
Anyways, thanks for the help guys. I appreciate it!!
Step by step:
Bulb size 9006.
Hmm? Im running a 35w Plug and Play HID kit in my Fogs with no issues. I would look into that switch or wiring in the stalk.....idk. Try plugging it up in another buddies GS and see if its your HID kit. If you lived by me, Id test your kit out for you since its a matter of plug and play.
sorry TL i cant get on ebay on the work server so i cant see the specs of the HID kit, check with some of the lighting vendors and they should be able to help you out with this issue. BTW im selling a relay kit in one of my classifieds IF you end up needing one for cheap, i was hoping to get it to stop mine from only powering up one on start up and it didnt so i never used it
I got DDM slim HID in my headlight and foglights Plug and play works no problem...
if it works you didnt cross the wiring, I would say the wiring is fine I think its the Kit itself Ebay.... If I were you Id just get another different kit theres a thread on here which brand but personally I liked my DDM kits for the price and quality looks good too me
Question do you have upgraded turn signals? Rear LED? or anything else that would draw more power than stock
mine worked with the car off so thats why im assuming its the kit
I have no upgraded turn signals or LED's just stock HID low beams and now HID foglights...
Yes, get a Fog Lamp Relay wiring kit.
Pretty much it consist of a relay, connections to the battery, connection to you existing foglamp wire, and outputting wires to both your ballast.
This ensures that power is not drawn from your existing foglamp wire. It'll utilize the power from battery and trigger from your existing foglamp wire.
