Fender roll or not??
After some search i did not found an answer to my question??
When i wanne mount some 19x9 +35 and 19x10 +45 with 235-35-19 and 245-35-19 do i need to roll my fenders??
yes roll them unless u wanna rub like crazy i have the excact same wheel fitment *** u but then i guess it also depends on how low u are n iwas 2 in. off the ground so i kinda had to
Do not roll the fenders. You have to shave them off. I just did it on my car because I just installed coil overs and put spacers in the rear so the rims would line up flush with the fender. Rolling the fenders will only create dimples. Find a DIY on here on how to shave/ trim the fenders.
man shave the back until all the holes on the edge are gone then roll them, u'll get stock body lines no dimples and front u'll be ok if ur nto 2 low ur car usually squats when u turn, and also use heat gun to roll them wont crack ur paint or better yet heat lamps.
