Rubber jack pad
Old 09-22-10, 03:22 PM
GSteg
GSteg's Avatar
Originally Posted by pizdets17
I was talking about jack stands rather than the jack, that wont bend the pinch welds?
You don't see the jack stands in the picture?
It won't bend as long as you put your jack stands exactly where they're suppose to be.
Old 09-22-10, 03:33 PM
pizdets17
pizdets17's Avatar
Just seems wrong lol pinch weld is thin jackstand is thick
Old 09-22-10, 03:40 PM
GSteg
GSteg's Avatar
I know it looks bad, but it'll be fine. Just have the jack touching the differential as a third jack stand. I generally have the jack lifted until I feel some resistance through the handle and then I stop.
Old 09-22-10, 04:54 PM
pizdets17
pizdets17's Avatar
If I die, I'm gonna kill you
Old 09-22-10, 05:23 PM
GSteg
GSteg's Avatar
Well if you die then you can't kill me
Those 2 and 4 post lifts at the mechanic shop uses the same jack point anyways.
Just make sure the jack stands are seated properly and triple check everything.
Old 09-22-10, 05:28 PM
LiCelsior
Retired
LiCelsior's Avatar
gsteg knows his ish, i use front xmember and rear diff most of the time. after i drive on some 2x4s.
Old 09-22-10, 05:36 PM
pizdets17
pizdets17's Avatar
You mean so the line of the pinch weld is in the middle of the jack stand?
Hbhandal
09-27-20 05:15 AM
DftMachine
01-07-19 05:50 AM
smokyis350
04-05-15 09:18 AM
redliner8
07-18-11 05:11 AM
BCP43002
11-25-09 11:32 AM
Quick Reply: Rubber jack pad
