Rubber jack pad
Old 09-21-10, 09:29 PM
pizdets17
pizdets17's Avatar
Default Rubber jack pad
Got a racing aluminum jack but the round cup thing has teeth that are way to big for jacking by the crossmember. Any idea where a guy could get a rubber pad that slips over it? Kinda like the one the guy has in the "jack your car up DIY"?
Old 09-21-10, 09:35 PM
D-Boi
D-Boi's Avatar
i dunno what the deal is with japanese steel but i think its total garbage, ive managed to cause damage when lifting my gs even with the stock jack placed in the proper place, on flat ground, moving the jack up very slowly and steadily. i have to use a piece of 2x4 to jack my car up because if the weight is not spread out over a length of 2 feet it will bend and destroy everything, this was the case in all 3 of my GS's on the other hand when i jack up my mustang i cant even so much as put a scratch on the lifting points.
Old 09-21-10, 09:44 PM
pizdets17
pizdets17's Avatar
yea both my front pinch welds are pushed in, and this new high end $350 jack has too big of a cup for the cross member, so that is why I need this thing, but cant see to find anywhere...
Old 09-21-10, 09:45 PM
sleeper408
sleeper408's Avatar
I've read that some members use a hockey puck.
Old 09-21-10, 09:56 PM
D-Boi
D-Boi's Avatar
i wish i would have used the 2x4 method before i destroyed evey jacking point in the car, its soft as butter it is
Old 09-21-10, 10:05 PM
lo_dit
lo_dit's Avatar
lol i use an extra headlight rubber grommet. but a hockey puck does sound pretty legit.
Old 09-21-10, 11:31 PM
pizdets17
pizdets17's Avatar
here in canada we have a lot of hockey pucks. Just to check since i am a total newb, its right under the lca#2 that the jacking point should be right?
Old 09-22-10, 06:13 AM
97JZA80
97JZA80's Avatar
Harbor freight sells those jack pads pretty cheap. I got one, but havent been under the car much since I bought it. Its pretty thick tough rubber though...
http://www.harborfreight.com/floor-j...pad-96306.html
They also make those pinch weld adapters for jacks that have a removable top piece....I havent used one before but have always been curious.
example here, Ive never used this website, for pic purposes only.
http://www.autobodytoolmart.com/grip...r-p-12467.aspx
Old 09-22-10, 09:01 AM
vwynn
vwynn's Avatar
i kinda jack up my car the wrong way... i jack it up via the tow hooks up front....
the back i jack it up on the rear diff.
Old 09-22-10, 09:12 AM
pizdets17
pizdets17's Avatar
I use rear tow hooks too lol. Another question is where the f@@@k do you put the rear jack stands as the frame rails seem to end in the middle of the car? Pic?
Old 09-22-10, 11:07 AM
pizdets17
pizdets17's Avatar
Dammit, that pad is 5 and 1/4" mine is only 4"...
Old 09-22-10, 01:11 PM
GSteg
GSteg's Avatar
You can put your jack at the rear OEM jack point.
Kinda like this:
Old 09-22-10, 02:24 PM
pizdets17
pizdets17's Avatar
I was talking about jack stands rather than the jack, that wont bend the pinch welds? Also is that right under the control arm #2 that you jack up the front? Sorry about all the stupid questions, I just bought this huge jack and trying to figure out how to not mangle my car...Still can't find anything that fits the jack cup thingy either...
Kinda like this:
Old 09-22-10, 02:40 PM
onihc
I heart Honda
onihc's Avatar
i have seen pictures of people putting jack stands under the lower control arm right beneath where the shock bolt is. i have never done it myself.
to jack up the car on the sides, i remove the "cup" on the jack to reduce crushing of the pinch welds.
Old 09-22-10, 02:50 PM
pizdets17
pizdets17's Avatar
Well thats the problem, like I said front pinch welds were ruined by a 18 yr old kid at the tire shop last year so cant use them at all...
Quick Reply: Rubber jack pad
