Rough idle after timing belt
Is there a way to check the timing via a timing light?
The car did sit unplugged for awhile and I do have a srt Intake and ecu
also i upgraded the alternator and changed out brake master cylinder
Its smooth if I give it Gas idles very rough
above 1000 feels fine just very very rough at low RPM
What you guys think
Im just hoping its not off a Tooth
What you guys think
yah I do need a scan tool my car has always idled low since day 1 when i bought it with 60k miles
Im going to change the fuel filter anyways and see because after seeing pictures im sure its gonna look bad, also if my car sits for more than 3 days when starting it will die unless i Rev it
