Need advice.how to remove back door lock
Hi.i'm trying to remove a lock from back door to change actuator,but i can't pull it out.i was trying to remove handle ,but i cant reach second screw.anyone done it before?thank you in advance.
See my freshly typed up DIY:
https://www.clublexus.com/forums/gs-...epair-diy.html
You need to remove the outside door handle to allow spacing for the lock assembly to be removed. You will need a small 10mm crescent wrench (about 4" long) to loosen the innder 2 bolts holding the outside door handle to the door frame. See my DIY notes.
