Seeking info for speedlimit cut on aristo ecu
Ok i got a swap on my 98 gs300, I have a apexi rev speed meter and it incorporates speed limit cut. i followed all the installation on the paper but it does not cut the speed.
I top out at 120mph which is horrible.
Ive done research but im not sure which diagram to go off of.
heres the HKS diagram:
here is the apexi diagram:
this is the old diagram which is for the aristo motor
this is the current one which is for a M/T Supra
Well, I wouldn't use the HKS diagram as that is for an HKS SLD Type II. I would use the T-10a diagram provided by Apex-i. Silly question, but do you have the speed cut feature turned on? Are all the vehicle settings correct? Is the RSM operating correctly on all other features or are none/some of them not working as well?
@SLVRGS300 on the Apex'i RSM I can see my RPMs, Speed and everything. The speed matches the cluster speedo, but i played with the settings in speed cut and still cant seem to cut the governor. I adjusted the setting as the diagram and cut speeds at 160,170,180.
Well I also have the HKS SLD lying around too, I just found out that the Apexi can cut speed, so I might as well use that. Im like seeing different location of speed wires and they dont match any diagram that are provided.
tonysc400
Performance & Maintenance
09-18-09 08:38 AM
