gs350 valve spring recall
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
so i work for lexus as a tech and have done multiple IS350 and GS350 spring recalls. i dont own one but from doing multiple recalls and hundreds more to come i would gladly hand my keys to the dealership as ive noticed lots of negative talk about it. it is a big job, we replace the springs with heavy duty springs, replace the hydraulic lifters with new ones and all the gaskets and seals. the valve spring kit alone costs 1500$ every one that i have done has had noticably better acceleration, increased throttle response and all around more power. besides the fact that as techs we get screwed by only getting paid 7 hrs for the whole job that takes 11-14 depending on the tech i think as a customer you should be thrilled. as long as the tech doesnt make a mistake and damage something, which even if that did happen lexus or the dealership would have to cover the mistake. the worst part of the recall is trying to set up the cam chains. the timing is very tricky. swaping the springs with the special tools is a breeze
I gotta ask cuz I have gotten a Pm from a moderator when i tried to help others...
how does this help what meaning does this post even have ....
what is the point?
you work for lexus... and say what... exactly
you are paid for 7hrs when ur supposed to get 11 and........
"as ive noticed lots of negative talk about it."
ok so its a recall like the pedal recall are they not properly fixing the vehicle afterwards or what??
what is the point?
Cut-Throat
04-12-11 10:52 PM
