oil change
Old 10-03-10 | 09:29 AM
Big Mack's Avatar
Big Mack
Cool
Originally Posted by Kansas
I've never had to put a Toyota or Lexus car on jack stands to change the oil but I do sometimes raise the car on the front passenger side a few inches with a floor jack. (I reach under the car and never put my body under it.) I lower the car down while the oil is draining from the sump. I've got a separate catch pan for removing the oil filter.
How on Earf do you get the rear retaining screws for the undercover without getting under the car? I always have to lift mine, as those are just about 4 feet back. Maybe from the side, but that's a huge pain. And if you're using a creeper, and still don't have to raise it, that seems strange to me.
You will need a 14 mm socket to remove/reinstall the drain plug and a 10 mm socket to remove the fasteners holding the engine undercover. A short 2"-3" socket extension might be helpful. You GS likely has plastic threaded inserts at the front of the undercover so gently tighten those when reinstalling the undercover so you don't strip the threads. If someone else has been changing your oil, you might find some of the inserts already stripped -- I keep a couple of replacements on hand because I occasionally strip one too.
Assuming you are going to take the oil to a recycler, you will probably need a a couple of plastic jugs and a funnel to get the oil into them.
And something to keep your garage floor clean -- a drop cloth of some kind ... a few layers of newspapers can work too. Have some rags or paper towels handy. I buy surgical gloves by the box to keep my hands clean while doing the dirty work on cars.
Wiggling around on a cold garage floor is not my idea of fun. I have a creeper with a padded headrest.
All good words of advice. I use surgical gloves, too, and have it down to a process where I can get the whole deal done in less than 30 minutes. It would take longer to drive and wait for it to be done than it takes me to actually do it.
Big Mack
Old 10-03-10 | 01:49 PM
alexdan's Avatar
alexdan
just go in there and DO IT!! to many question about such a simple process.
you got it brother !!!!
Old 10-03-10 | 02:46 PM
vwynn's Avatar
vwynn
http://www.youtube.com/watch?v=wQZY1jon87c
kinda shows you simple instructions
btw dont mind the OE jack.. i didnt use that to support the vehicle. Use jackstands of course,
Old 10-03-10 | 04:41 PM
pizdets17's Avatar
pizdets17
thank you sir.
Old 10-03-10 | 05:37 PM
Kansas's Avatar
Kansas
Big Mac, the rear bolts of the engine cover are far short of four feet back from the front lip of the bumper cover. Look at the attached 04 GS430 undercover photo. Measure and I think you will find that the rear fasteners are about 31 inches back. I'm a normally proportioned 6 foot, 180 pound male (shirt sleeve length 34 inches) and have no trouble removing the engine undercover from the front without jacking the car up or putting it on jackstands.
Big Mac, maybe it is your "bigness" that is keeping you from reaching the rear fasteners?
Leowaxx
CL of Southern California
03-29-14 06:21 PM
dysLEXic
Maintenance
03-03-08 04:05 PM
JWS3
GX - 1st Gen (2003-2009)
11-08-07 01:51 PM
br3akenout
04-20-07 12:17 PM
clubaddict
Maintenance
06-05-06 05:30 PM
Quick Reply: oil change
