Timing belt help?
I was wondering if anyone would give me a list of the parts needed to replace the timing belt as there is no timing belt kit for a 98 gs 300 twin?
Ahh, but there is.
Over at AutohausAZ (for $233, Oct '10) the "kit contains a Mitsuboshi timing belt, an Aisin water pump w/ gasket, and a Koyo tensioner bearing." What the kit does not contain is two (or three?) O-rings for the small metal pipes or in/outlets between the water pump and the block which I picked up on the moment from the dealer for 10 times their value. I will also go in later to replace the hydraulic tensioner, just because mine is looking a bit corroded and because belt & chain issues often are attributible to the tensioner. Other members here have opinions about cam seal replacement. As your coolant system is open, now might be a good time to replace the fluid. I also found it convenient to disconnect the tranny coolant and lost a small amount.
If you're on a budget the absolute minimal list is just the belt, which can be had for around $30.
A thorough list is as follows...
- belt
- water pump and gaskets
- O-rings
- tensioner bearing
- tensioner
- cam shaft seals
- coolant
- small amount of tranny fluid
You will need to solve the crank nut problem, which for me required a vice grip on the harmonic damper/balancer and a 24" vanadium steel breaker bar. In my case the break-loose torque is estimated at around 200 lb-ft., enough to bend my cheaper 18" torque bar. The harmonic damper removal tool and 24" bar are both available at AutoZone or through Amazon.com
- belt
- O-rings
- tensioner bearing
- tensioner
- cam shaft seals
- coolant
I have a '98 GS 300 and bought parts to do the timing belt/water pump replacement. These should be Toyota/Lexus part numbers...
#13568-49036 Timing belt
#13505-46041 Idler, T/B
#13540-46030 Tensioner
#90210-26002 Washer
#90311-40020 (2) Oil seal
#90311-46001 Oil seal
#16100-49876-83 Pump assembly
#90916-03093 Thermostat
#16325-62010 Gasket for thermostat
#96761-24022 (2) O-Ring
#96761-24028 O-Ring
#99366-D1930 V-Belt
Parts w/ tax came out to $502.61. Hope this helps.
#90210-26002 Washer
#96761-24028 O-Ring
#99366-D1930 V-Belt
