My 2001 GS430 is "hesitating" when I first hit the gas hard...
#46
Oh okay... so I will replace BOTH then! Okay... gotcha. Thanks
Hey, what's the best way to clean the MAF? Do I have to take it off to do that?
I'm ready to just take it the dealer and say "Find out what the Check Engine light keeps coming back on." I don't know where anything is on my GS... How tricky is it to replace the PCV or see if there's a leak around it somewhere?
I'm just not sure where to start... ahh.
#47
if you take it to the dealer, they gonna do exactly what were advising you to do first and will charge you a fortune....
you'll never know where anything is on your GS if you dont get hands on with it, although normally if its engine wise i tend to leave it in someone else's hands also lol.
PCV is simple man....
start SLOWLY
#48
Okay.. you're right! I'm going to DEF do the PCV valve.. (and check the hose to make sure it's not a leak causing the check engine light)
Last question- Is it okay to replace the Fuel Filter with an aftermarket one, vs. buying one through the dealer.. or even buying a more expensive Aftermarket one, say on ebay? What do you think.
I am going to change the fuel filters tomorrow and the PCV valve, and hope that solves my problem. I am thinking it's the PCV though.. b/c P0171 is "bank 1"- and I'm pretty sure that's the side with the PCV...
I hope!!
It makes me feel better than even you said this, haha:
Thanks bro!
I hope!!
Thanks bro!
#50
PROBLEM FOUND and SOLVED! One of the prongs on the MAF was bent, and it needed to be cleaned. That was it ! Now it's back to 300hp! It breaks the tires loose if I jump on it now.. big time!! WHAT A DIFFERENCE!!
I'm going to do the Fuel Filters, still.. but I'm waiting until spring time to do those.
(too effin cold now!)
As far as the PCV valve- I bought a new OEM one.. It was $5.72 w/ tax.. is it even worth replacing the stock one ? I haven't been able to even LOCATE it! Can anybody put a close-up pic of where it's located at, on our engines?
Thanks again for the help fellas...
Car Freak
02-21-05 08:52 PM
