Transmission Fluid
Old 10-15-10, 07:18 AM
LuxuryGS3
LuxuryGS3's Avatar
Default Transmission Fluid
So I decided to check my tranny fluid along w/ oil this morning and when I pull out my tranny fluid and put a couple drops on a white paper towel it turns out to be a dark purplish color..
I was reading up and I read that it's suppose to be a light red color.. I don't think it'd go bad already considering I just did a tranny flush about 2 months ago. Maybe less than that.
I drive a '98 GS300 and the fluid that I used after my flush was the one the owners manual states to use.. Fluid type T-IV..
Anyone care to shed some light on this? Think I need to do another flush or ???
Old 10-15-10, 09:24 AM
vwynn
vwynn's Avatar
yea T-R fluid is supposed to be nice cherry red n smell sweet. looks like your fluid is getting roasted quick. Did the place before actually FLUSH your car or say they flushed it n drained n filled?
Old 10-15-10, 11:23 AM
LuxuryGS3
LuxuryGS3's Avatar
They just lifted the car up and drained out the old and stuck in the new.
Old 10-15-10, 12:28 PM
toy4life86
toy4life86's Avatar
your gonna have to do the drain and refill a couple times to get it fresh
Old 10-15-10, 01:42 PM
SorrGwa
SorrGwa's Avatar
drain and fill will only get u a bit.
go to a toyota/lexus dealership and ask for a low pressure tranny fluid flush. should take up to an hour, and take up to 12L of tranny fluid. majority of the tranny fluid is in the torque converter, which a drain and fill cannot take out.
Old 10-16-10, 01:33 AM
YviE
YviE's Avatar
I'd just fill and drain it a few times with short intervals. That's what I'm currently doing. The fluid is getting pretty red color by now.
Old 10-16-10, 10:24 AM
vwynn
vwynn's Avatar
That only changes 2 quarts of fluid. Not a flush at all. Hopefully they didnt rape you in cost for doing a "flush".
as stated above flush is about 12 quarts not 2. the good is that all the fluid is removed and the fluid will be cherry red. The downside (from what ive heard/read) is that itll dislodge some of the gunk in the tranny and mess up the insides?
its up to you really.
Old 10-16-10, 12:58 PM
McKrevice
McKrevice's Avatar
Depends on miles. If there are over 100k I wouldn't do a full evac.
Old 10-16-10, 04:25 PM
RLGS300
RLGS300's Avatar
I have been doing tranny fluid changes every 30k since the car was new back in 2000. Is that a bad thing?? i hope not!
Old 10-16-10, 05:12 PM
alexdan
alexdan's Avatar
thats a very good thing
Old 10-16-10, 05:41 PM
McKrevice
McKrevice's Avatar
drain and fill or full evac?
Old 10-16-10, 05:52 PM
RLGS300
RLGS300's Avatar
^^^^^drain and fill, occasionally ill take the tranny pan off and replace the filter thats inside
Old 10-16-10, 07:07 PM
McKrevice
McKrevice's Avatar
Ok. Just wanted to be sure. That's a good habit to get into. I usually do a drain and fill once a year.
Old 10-17-10, 11:21 AM
LuxuryGS3
LuxuryGS3's Avatar
Thanks for all the reply's guys!
Think i'll hit up my closest Lexus dealer and do a low pressure tranny flush.. Will call in the next couple of days to get a quote on how much it might cost..
McKrevice: My car has 141k miles.. What do you recommend doing?
Old 10-17-10, 11:29 AM
McKrevice
McKrevice's Avatar
I'm no pro so check with a shop that you trust or a mechanic you trust. I as always under the impression that if the car has never had a full evac, doing one with that many miles is looking for trouble. You wash away all of the deposits left by the old fluid which in fact may be helping your trans. You wash that away and you are asking, I believe for leaks or other problems.
I have never done a full evac on my Ford Escort winter beater, just 3 drain and fills for the past 100k miles and after I do one it runs fine. I did do a full evac with Amsoil on my 2000 GS400 in 2008, but it only had 34,000 on it at the time.
This might be an urban legend, but I have heard of this for years.
Someone with more knowledge will chime in I'm sure.
Quick Reply: Transmission Fluid
