Acceleration hesitation problem......
I've reviewed threads on this topic for months on end, so i understand that some folks experience a slight hesitation when the hit the throttle in their GS.
I've definitely noticed this myself, but it also seems to occur when the car is in certain inclines/turns. What I have noticed is every morning on the way to work there is an uphill right-hand turn from a stop sign that EVERY time i take it, my car bogs down for pretty much a full second.
Anyone else have this type of observation??? Is there a known solution for this problem??
Thanks all,
Eric
Thanks all,
Eric
this is just a guess, but if you're going uphill, the car may have already switched to a low gear going high rpms and just needs a little time to either move up another gear. if it is in a low gear with low rpms, then that's just typical. these things don't gun right when you step on the gas. if you have e-shift, shift down one and you'll see your rmp shoot up and that'll kill the hesitation somewhat
This happens to me all the time especially when I dart out of a lane into another lane and I need to accelerate quickly....it feels like a slug...
I think it's the transmission hunting for the right gear...I guess it's a tradeoff between smooth shifts in the auto tranny or quick response but with jerkiness.
Brent
Brent
i think it's partially a rear wheel drive thing. i know many rear wheel drive cars dont lag as much as the GS sometimes does but my ES is fwd, and i'm used to the quick response....and then i drive my pop's GS and the car kicks like a horse. and then i realize i start doing all these things to make sure the rpm doesnt get too low to prevent the kicking....like rolling stops at stop signs and stuff. if ya want less lag in a rwd, drive a rotary engine car.
Originally posted by mrsypher
I got the same problem.... I think it has to do with the Exhaust and Intake.... I need a ECU that can change my air/gas flow...
Originally posted by qqqxppp
i thought it was because the wheels were slipping and the VSC was trying to regain traction.
the hesitation is just apparent everywhere and not in a particular situation. if you try to quickly accelerate, you'll always lag unless you e-shifted into a lower gear and are already in high revs
Don't have any hesitation ...yet...knock on wood.
I have trained my right foot to be ever so gently in stepping on the gas or else, the car jumps. No kidding.
My initial thoughts on your problem was the TPS. Why? Because the TPS controls the first initial trigger to advance the engine timing to get your car going. Without it, the engine's timing is the same as in idling position and therefore not optimized for getting you out of the hole, ie acceleration from stop.
When I said TPS, it could mean the TPS assembly itself or the way the TPS was calibrated as it was mounted on the throttle body.
Will post back if something triggers to mind why you're having that hesitation.
I know when I floor the car, it takes maybe 2 seconds for the car to kick in. After 2 seconds, it flies. Its almost like theres a boost lag, except for the fact that I dont have boost. Its like you get pushed against your seat, but you dont actually go faster for another 2 seconds till it kicks in.
Is this the problem your encountering? If so, i think Bliu got it right. Even though it is abvious that your car would go into 3rd gear after second, because of the overflow the ECU is getting, it has to think about or it just takes longer... somethin' like that.
When I first got my GS it never hesitated.. Then after I put on my Intake/ Exhaust that's when it started......
