Fuzucked up my headlights.!!!!!!!!
A number of years ago I made the mistake of trying to clean the crystal on my watch with a lightly abrasive product. The crystal is some kind of acrylic - probably similar to the headlight covers. I had the same thing happen. The crystal was milky white. I took it to a jewerly store and he was able to polish it out back to its original condition. I'm not sure what he used, but you might want to check with a high-end jewelry store that does repair on the premises. They might have a product that you can use.
350 is very rough man... i cant belive it looks that good even!
what u wanna use is a 1500 grit in cold water, and then use a compound to rub out all the minor scratches that are left over.
But i think that scratch remover for plexi-glass works reallly well because i woiuld have though a 350 would have ripped that up! it must be either really hard plastic (which means the 1500 sanding will take a while) or the scratch remover is really good.
Best of luck man. It sounds like the scratch remover works as a compound (since it basically is)
hey guys here is the picture of my headlights right now. haven't tried anything yet. look at them and compare them to robbsneaks picture and you can see how bad they are
another angle
yes i know i have bugs on my car. its extremely dirty right now. haven't washed it in 1 week. and its a black car. so those of you with black know's how often you gotta wash it
try the compound i was tlaking about, and see if u can get a plexi-glass polish that should do the trick... i really dont knwo but please share yoru results im extreamly interested.
all i did was took my headlight off my car and use a bottle called "Blue magic" plastic and plexiglass cleaner and light scratch remover. and started really scrubbing at it little parts at a time. all of a sudden the scratches were GONE. my car looks 100% better now.
Northern California Regional Officer
That's amazing! When I saw your original photos I would have figured your lights were trashed. Honestly, I probably would have purchased new ones after seeing that!
Good job!
Good job!
