TTE replica install frustrations!!!!
Old 10-25-10, 10:25 AM
Frankdorn
Frankdorn's Avatar
Default TTE replica install frustrations!!!!
Yeah, I learned my lesson...
But, I have a TTE replica in my garage painted to match the car, and I wanna put it on.
I am SO pissed off!!
There are three mounts standing up, the outer two of which are misshapen at least, probably too tall, so I took 1/4" off the tops. Even with that, on the bottom the whole lip is away from the bumper at least 1/2" everywhere except the three standoffs and the tips of the ends. Where would double-sided tape or epoxy even be applied? Even if I mount at those points, it doesn't even look like the front face of the lip would stay up against the bumper--more like it would sag down.
HELP, PLEASE!
Attached Thumbnails TTE replica install frustrations!!!!-tte-lip-001.jpg   TTE replica install frustrations!!!!-tte-lip-002.jpg   TTE replica install frustrations!!!!-tte-lip-003.jpg   TTE replica install frustrations!!!!-tte-lip-004.jpg
Old 10-25-10, 10:46 AM
aEO 37
aEO 37's Avatar
The fitment looks pretty good on it. looks just like the real TTE lip
If I remember correctly. You would apply the epoxy along the top back side of the lip, from side to side. There should be a total of 5 screw, 3 along the font and 1 at each corner. I didn't bother to use double sided tape because it would just sag down over time.
Old 10-25-10, 10:49 AM
benbuilt4u
benbuilt4u's Avatar
fitment looks good weatherstrip adhesive is your freind. add it then tape like you did.
Old 10-25-10, 11:07 AM
D-Boi
D-Boi's Avatar
the strongest epoxy i ever used was the black stuff they use to hold on windshields, you could not pry this stuff off you had to blade it off, really strong stuff i love it. on the other hand sir where can i buy the rep TTE?
Old 10-25-10, 11:09 AM
/209JOHN\
/209JOHN\'s Avatar
paint looks good,
did you pre-fit everything before you painted it? Often, the aftermarket parts never fit exact.
Old 10-25-10, 11:18 AM
5t341th
5t341th's Avatar
imo, the only way to make the upper portion not sag down is to screw it in. and my lips real too
Old 10-25-10, 11:36 AM
Anthony
Anthony's Avatar
i had the same problem..yep^ thats what i ended up doing than putting filler over it sanding and paint..its never comming off and atleast you wont have to worry about someone stealing it lol..
PHML
Master Thread Closer!!
PHML's Avatar
You need to use some kind of adhesive like epoxy or silicone on the backside of the entire upper trim of the tte lip...that's how it stays up against the bumper. The 3 bottom mounts ont he bottom is to keep the tte lip up from sagging (ie: so it won't snag onto those dang wheel stops bolts/nuts/rebars and rip the lip or your bumper off the car).
Old 10-25-10, 12:43 PM
gsjason300
gsjason300's Avatar
if u guys can really see what i did.... hahahahhahaa u will be like idiot....
Old 10-25-10, 01:14 PM
ALowGS
ALowGS's Avatar
Looks good to me. And i am just gonna agree with everyone, apoxy is the best solution
Originally Posted by D-Boi
...on the other hand sir where can i buy the rep TTE?
D-boi, search tte in the LA craigslist. he sells them there and he ships.
Old 10-25-10, 01:20 PM
RLGS300
RLGS300's Avatar
is this an unbranded lip or is it like the VIS lip?
Old 10-25-10, 02:27 PM
V8RdnLow
V8RdnLow's Avatar
I believe VIS is the only company that makes the TTE rep
Old 10-25-10, 02:30 PM
speedaddic
speedaddic's Avatar
in the bodyshop we used to use 3m DURAMIX
Old 10-25-10, 02:45 PM
TLcoats
TLcoats's Avatar
Wow look how thin that fiberglass is. I scrape mine ALL the time and i'm not even THAT low. Can anyone comment on how the durability is on these? Also the adhesive to use is this windshield epoxy.
Attached Thumbnails TTE replica install frustrations!!!!-31s36xw4dkl._sl500_aa300_.jpg
Old 10-25-10, 06:13 PM
cjames235
cjames235's Avatar
dont use 3m tape! i tried and it just wont hold for more than a couple days on that little bit of bumper in the front that it hangs on to
definitely windshield glue i used it all along the top edge of the front section of the lip....... the only other thing i have holding it on is a couple screws on the backside of either end going into the very edge of the bumper in the fender well
i didnt use the mounts on the bottom (i actually cut them off to get a little better fit)
TRUST ME that friggin windshield glue will NEVER let go, it will have to be cut off if it ever needs replacing
Quick Reply: TTE replica install frustrations!!!!
