*PICS* 20x10" 20/25mm offset w/ a 5" Rear Lip Wheels - TIRE QUESTION
I'm in the process of finding some new rear tires and have a few questions...
I'm having a hard time finding good prices on 255/30's for the rear, but found a smoking deal on some new 245/30's @ $120 each.
Has anyone put a 245/30 on a 10" wide wheel before? Will it be safe to do this?
Or should I take my front 245/35's tires which still have 70% tread left and move those to the rear and put the new 245/30's up front to eliminate the fender lining rubbing issue that I currently have?
Here is my current setup...
Front Setup:
20x8.5 w/ 20mm offset
245/35/20 (slightly rubs on fender lining)
DIY Hand Fender Pull
Rear Setup:
20x10 w/ 25mm offset
255/30/20 (no rubbing)
Fenders Cut Flush
***My current ride height is about 1/4" lower then what you see in these pics***
Front Setup:
Rear Setup:
Fenders Cut Flush
Just got back from the tire shop and the 245/30 up front is perfect... no more rubbing on the inner fender lining. I also really like the look of the 245/35 on the 10" wide rears. More stretch makes the rear wheel look even wider
Will post a few more pics to show the difference.
I originally had the 245/35's up front and some old worn out 255/30's on the back.
I took the 245/35's that were up front and moved them to the back. And purchased 245/30's for the front. I would have gone 225/30 or 235/30, but those were not in stock. I got them new for only $120 each installed which is a pretty solid deal.
In this pic you can see how the 30 series on the front tire looks...
