Wheel width/offset/size and tire fitment Q&A thread
#301
If i'm correct those should be nearly flushed. I say do 225/35 fronts and 245/35 on the rears and just max camber.
My next wheels that are getting redone are gonna be 19x9.5 +10 and 19x10.5 +10. Did some calculations and it should be flushed.
Since my previous wheels were x9 +5 and x10 +5.
Should stick out 7.7mm than before.. If I am correct..
#302
#303
Half inch 12.7mm and since i'm +5mm less aggressive it would of been 7.7mm.
But good to know I got the right amount of poke I want.
Anyways I found a link on VSC that would help a lot of us here.
http://www.1010tires.com/WheelOffsetCalculator.asp
#304
Ah alright thats good enough. I figured since, I'm upgrading to half an inch..
Your new wheels are 1/2" bigger (12.7mm) but that means only 1/4" bigger on the inside and 1/4" bigger on the outside, (6.35mm)
so with the same offsets you would be 6.35mm more poke, but you have 5mm less offset.
6.35mm - 5mm = 1.35mm more agressive like tiger4life mentioned.
a 1" bigger wheel with same offsets would stick 1/2" inside and 1/2" outside larger.
#307
On Megan coilovers.....
Bolt pattern : 5 x 120
Size : 19 x 8.5 (F) & 19 x 9.5 (R)
Offset : 20mm
Hub Size : 72.56mm
Its BMW M6 rep;s.......I know I will have to redrill or what have you.......but aside from that will it fit?
Offset : 20mm
Hub Size : 72.56mm
#308
