Wheel width/offset/size and tire fitment Q&A thread
#393
I believe 225/35R19 are not ganna be easy to find. more common is 215/35.... plus the stretch will be closer to the stretch of the 9.5 235/35R19.
#394
![](http://i171.photobucket.com/albums/u318/whit3b0y_photos/th_IMG374.jpg)
#397
I am going with some BMW 7 Series wheels on my 2GS, with shaved rear and rolled front fenders. 19x9 and 19x10 with +5 offsets all around. A friend use to have the same set up and it sat flush on his GS. However when I get them on my car, dropped with maxed out camber it isnt sitting as I expected, tire is basically sitting on the tire. Anyone know why this may be?
Am I gonna have to adjust my coilovers even lower to get the tires to cave in more? I believe about 12mm of tires still needs to be tucked.
#398
Hello,
Can someone tell me if these winter tires will fit my 07 Is250 awd. I am getting them w/wheels for free if they will work. Wheel bolt pattern is 114.3 x 5 50 mm offset. looking on sites it appears the wheels will fit. The tires are 215/55 r17. Will the tire height be too high and rub?
thanks
thanks
#399
Hello,
thanks
thanks
#401
Hello,
thanks
thanks
Well some members will know. +50 offset should fit pretty much any car with no problem.
#403
Why not roll and shave your fenders?
If you want to run aftermarket wheels might as well roll and shave your fenders it'll save you the hassle and it'll open up a lot of opportunity to different type of wheels.
ROLL AND SHAVE YOUR FENDERS.
#404
Style 95 with that size tire will not fit unless you ran a ton of camber.
You could probably get away with a 255 on the rear and a 245 up front with reasonable camber.
I ran 245 rear and 235 front on mine, -1.5 degree rear camber, and around -1.75 front iirc, didnt rub much in front, but I rolled fenders all the way around
#405
i have a 2nd gs im looking to get 20x9 offset +38 tire 225/35/20 will i rub in front or back? or on turns? i was running 20x8 35+ offset tires 225/35/20 and had no rubbing in the back but fronts i had some rubbing on turns and some big bumps.. im also lowered on coil overs
http://sphotos-a.xx.fbcdn.net/hphoto...97204275_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...56617277_n.jpg
http://sphotos-a.xx.fbcdn.net/hphoto...24060748_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...38667897_n.jpg
