Wheel width/offset/size and tire fitment Q&A thread
#438
Hey guys what's the widest low offset setup I can go without modding my fenders? I'll be glad to add camber to compensate. My last setup was 19x10.5 +22 and I just dialed out my camber to about -3.1 and they fit perfect.
#442
My previous setup was wider than yours I'm trying to see how much wider than 10.5 I can go. I'm thinking probably 11.5 with a considerable amount of camber.
#446
Hi guys,
I'm planning on getting a used set of wheels from a 350zx I believe. They're 19" 8.5 ET35 with 235/35/19 front and 19" 9.5 ET 40 265/30/19 rear.
I believe that 350zx have hub bore of 66.1 and GS needs 60.1 so I'm expecting to have to get some hub centric rings for a smooth ride, my question is purely, as being a novice, can anyone see anything I may be missing.
Also, as a side question, if I were to fit spacers should I want/need them, would spacers with 66.1/60.1 bores adaption be something that is available or would I just have to get 66.1/66.1 and just use the hub centric rings?
Again, apologies if it all sounds obvious as I am learning all this as I go!?!
#448
just put these on my car few days ago 19x10.5 rear 19x9.5 front +20mm offset 245/35/19 235/35/19 debating on lowering car more but ride is like a dream with the big wheels and also getting wheels sprayed matte black
![Name: 164468_539439016066783_528159201_n_zps1125cca0.jpg
Size: 85.7 KB](https://www.clublexus.com/forums/attachments/gs-2nd-gen-1998-2005/429291d1501344156-wheel-width-offset-size-and-tire-fitment-q-and-a-thread-164468_539439016066783_528159201_n_zps1125cca0.jpg)
![Name: 424390_539629946047690_475288746_n_zpsaa70c058.jpg
Size: 83.2 KB](https://www.clublexus.com/forums/attachments/gs-2nd-gen-1998-2005/429292d1501344156-wheel-width-offset-size-and-tire-fitment-q-and-a-thread-424390_539629946047690_475288746_n_zpsaa70c058.jpg)
#450
what offsets for 20x10 all around to get pretty flush and clear front suspension gonna be running 225/35 in front and 245/35 in rear...... don't want the rims to poke trying to avoid fender pulling..... thinking 25mm up front and 20mm in rear but keep second guessing myself.....
