Wheel width/offset/size and tire fitment Q&A thread
#496
I was thinking about purchasing som MRR RW4 wheels with custom offsets. What offset would fit the GS best?
19 X 8.5 +?
19 X 9.5 +?
Also dont want to do too much fender work. Shaving and rolling is an option. What tire sizes would you guys recomend also?
Thanks in advance for all the help.
19 X 8.5 +?
19 X 9.5 +?
#497
19 X 8.5 +?
19 X 9.5 +?
19 X 8.5 +?
19 X 9.5 +?
19X8.5 25+ 245/35/19
19X9.5 22+ 275/30/19
If on coilovers
19X8.5 + 22 235/35/19
19X9.5 + 22 275/30/19
#498
19 X 8.5 +?
19 X 9.5 +?
19 X 8.5 +?
19 X 9.5 +?
#501
Brand: T.I. Wheels
Model: Ti 5
Size: Front 18x8.5, Rear 18x9.5
Finish: Black
Offset: 45- front 40 back
Lugs: 5 x 114.3
These were on a s2000
Would they fit my 02gs300
Model: Ti 5
Finish: Black
Lugs: 5 x 114.3
#502
Quick question since im about to swap tires at work. 19x10.5 +26. There is currently a 275 on there which i know wont fit, but what will it take to fit a 255/35. Just a shave or will i have to do a small pull? My camber was at -2 last time i got it aligned. This is rear btw
#505
Edit: I see you have a +24, so you're about 6mm less aggressive than me. The 255 will work, but you're probably going to have to at least run the 2.7 degrees I am, maybe more. I know for sure the 245 would be easy since I had plenty of space when I had the 20s.
#507
Need help Stock suspension For now.
want to run
Front : 19x9j ET 48 235/35/19
Rear : 19x10j ET 45 255/35/19
Will I clear both fenders/QP front and back.
Don't care about being Flush.
Just don't want to cut up the rear QP.
Will be dropped on Df210 Soon.
want to run
#509
Did u ever add the rear 20x13??? And what type of feder mods did u have to do?
#510
Anybody know how much MORE the rear wheels "stick-IN" on the 2GS compared to the front?
People said 20mm spacers up front and 35mm in the back in close to flush. (so I'm guessing that the Rear "track" is about 30 narrower than the front...) Sound about right?
(I installed the Exact Motorsports REAR RCA's with my (still, currently) STOCK Suspension- so even though I have the least amount of 'added' + camber, my rear camber is at 0.0% on the dot...
SOOOOO... If any of the PRO's on here that really know about our cars, & offset, specs...etc could help me out I'd really appreciate it. Thanks guys...
Not sure between 25mm or 30mm for the rear. Tough call.
