Wheel width/offset/size and tire fitment Q&A thread
#528
I'm looking for a non-staggered, slight to no camber, and slight to no stretch on tires (square setup?lol)
Anyway I'm looking at a 19x10+25 all around, will it give me trouble? I don't have a problem getting my fenders pulled or rolled. I'm also looking at 19x9.5+12 cause I was told those wouldn't be a problem at all. I'm planning to lower the car on coils after I get the rims if that makes a difference.
I could be wrong though, its been a while since ive been in the rim game.
#529
Hey guys....I'm looking at a set of 19x8.5+17 and 19x9.5+25. I'm lowered on Ltuned spring and want your opinion/pix
#531
I have the MRR HR3s in a 20x9.5 with 35 offset and tires are slightly stretched 225/35. I just recently bought 25mm spacers for the rear and I was wondering if any fender work will be required? Im lowered on the Tanabe sustecs if that matters.
#532
hey guys have a couple questions. I just recently purchased some 20x10 +35 front and 20x11 +35 rear. I am going to space them as needed to achieve the look I want. What I was wondering was if a 275/30/20 for the rear would work? And what do you guys think of that size? and i thought of a 255/30/20 for the front? also, will it fit and what do you guys think? Rears have been shaved completely and fronts have been rolled. Any help would be appreciated.. Thank you!
#533
im thinking about buying some rims off craigslist but im not sure if the offset will fit.
-Fronts: 20x8.5 (offset +20)
-Rears: 20x10 (offset +25)
will these extend out too much?
My car is stock height and i dont want any fender mods.
#536
About to make the switch from an sc300 to a gs300. Curious if my wheels from my Sc will work well on the gs. 20x9.5+13/20x11+19. How much work should I expect on the gs platform?? If too aggressive the I guess I will sell/trade for a more appropriate set. Trying to not run anymore than 4degrees out back and 3 up front. What you gs pros think?
#538
Nice.. Now I did a pull on my Sc. All I've ever done in the past are pulls. Would you mind going into depth on shaving? Is it as it sounds... Shave the lip that would usually be rolled flat? If so, any problems with the layers of the panel separating?
