Wheel width/offset/size and tire fitment Q&A thread
#557
I have question about some 19''x8 +20 for the fronts. The reason I'm asking a question about them is because I rarely see anyone running 8's, its usually 8.5 on up. The reason I'm going with about 8's is because the only available sizes they have on these wills are 19x8 +20 & +40, 19x9.5 +20 & +40. I'm going with the conservative 9.5 +40 at the rear and know they will fit and I know 9.5 +20 might fit with a ton of work. So my question again is will 8 +20 work on the front of my GS2 with just a roll or would it take more work then that? I would like to lower my car with no more then 1 finger gap 225x35 front tires.
#559
I've got a 99 gs300 lowered on Stance coilovers but currently sitting as high as they go. Thinking of running Vossen CV3's 20x10 +45 & 20x10.5 +25. The fenders are rolled & will run 245/35/20 all the way around. Is the roll enough or will the fenders need to be pulled? Also, any chance the 20x10 +45 front hits any of the suspension components?
Any input is greatly appreciated.
#563
All this info is confusing. I have a 00 gs400 and want to know what size rims in 19 & 20 and the tire size (width/sidewall size) that will fit stock ride height without modding fenders. Looking for widest tire and preferably same size on all 4ccorners
#564
It will with rolled fenders front and rear. 225/35 front and 235/35 rear
without modifications stick to offsets higher than +40. and tire sizes are based on how wide the wheel is.
#565
After months and months of researching.....I am ready to transform my stock GS430 into something else.
I finally pulled the trigger and bought Megan LP.
Also Leon Hardiritt Ritters
19x9.5 +30
19x10.5 +28
This is my daily driver and I wont be "slamming" it but i want a decent drop.
I was thinking about running
235/35 front
245/35 rear
I am a little flexible on the tires but I dont want anything TOO stretched.
Also what fender mod will i need to know.
I am constantly checking with the forums for any response. So please help. Thanks
19x9.5 +30
19x10.5 +28
235/35 front
245/35 rear
#568
EDIT: I should add, since you're going with a lower diameter you may want to change the profile from 35 to 40. Just search, there's bound to be someone running simillar sizes... .if not here, then on a different car. Just google it.
#569
If you don't have an answer or a question for this thread......you shouldn't be reading the thread.
Like stated in your signature......you are a HATER.
Thanks to the nice guy who PM'd me a response. No thanks to you.
Try waking up on the other side of the bed next time. Have a good day.
#570
Another 19" rim/fitment thread...
Looking at buying a set of varrstoen 19x8.5f et15 w 235/35/19 and 19x9.5r et20 w 245/40/19s... Car is lowered on eibach springs and I wanted to know if anybody has this exact same setup (rims at least) and if you had to do fender mods. I've searched and found similar like 19x9 or 19x9.5 fronts but always is et22 and never in 19x8.5. Anyone with this set up please chime in..... Thanks
