Wheel width/offset/size and tire fitment Q&A thread
#571
Looking at buying a set of varrstoen 19x8.5f et15 w 235/35/19 and 19x9.5r et20 w 245/40/19s... Car is lowered on eibach springs and I wanted to know if anybody has this exact same setup (rims at least) and if you had to do fender mods. I've searched and found similar like 19x9 or 19x9.5 fronts but always is et22 and never in 19x8.5. Anyone with this set up please chime in..... Thanks
People aren't answering anymore because the EXACT same questions are being asked over and over in this same thread. Please look through the thread BEFORE asking a question (the ENTIRE thread), and also make educated guesses.
Here are some websites you all can use to help get you all up to speed:
The 1010tires.com Wheel Offset Calculator
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Jonathan Rowney's Stance Calculator
http://www.jonathanrowny.com/page/offset-calculator
www.rimtuck.com
#572
Looking at these TSW Valencia's for my GS.
They come in a +40 and +20 offset. I want to fill the wheel well as much as possible but with no modifications. If necessary I could get my fenders rolled, but would like to avoid that if possible. What should I run for offset?
19 x 8.5 Front
19 x 9.5 Rear
Also, what would be the largest tires I could fit on these? (looking for a decent amount of sidewall for ride and protection against curbing)
19 x 8.5 Front
19 x 9.5 Rear
#573
Alright... now I have a question (I'm hoping Yakuza, Bippu, or SoCalSC4 can chime in), and I'd check myself, but I'm currently stationed in Korea and my car is still in England. Anywho:
Currently, I'm running 20x11 et30 rears with 275/30 tires and my camber is about -3 to -4 degrees. I'm looking to run a 20x12 et30 with 305/25 tires and camber set to approximately -6 degrees on my new setup. (For the record, my rears are shaved pretty thin and I currently have about a good finger gap between the fenders and wheels).
So far, after checking the offset calculator, the tires will have 13mm LESS inside clearance (and that's not taking camber into account). So, my question is: Has ANYONE ran similar sizes and would be able to tell me if I'll have enough space in between the tire and suspension/hub to actually run this size in the rear? I'm running coilovers at the moment, and will also be swapping out to an Airrex/Accuair setup, so I know that when I lower it, the wheels/tires will camber in more. I'm just trying to get an overall idea as to whether or not this setup is actually possible without having to modify the rear fenders anymore. Thanks.
#574
#575
You would probably hit the shock with 6 degrees. You would have to run something like a 275/30 on a 12 to get remotely close to fitting it. You will have to pull your fenders. Now if you aren't concerned with the wheel clearing the fender since you'll have air and just want to roll mexi-flush aired up, then go ahead. I would still take a 1/2" from the inside and run an 11.5 +24
As for the 275 on the 12, I was running a 255/30 on the 11 when I first purchased them but ended up swapping them to the current 275/30s. Where it's at currently is about as far as I'd stretch, not to mention, aired out with aggressive offsets AND meaty tires is I'm shooting for.
Can't do the mexi-flush bit as where I'm currently at with the coilovers is going to be my normal driving height when on air. Damn.. I just had the fronts done so I may have to get the rears as well and probably go with a lower offset so it clears the suspension as well.
Thanks Tiger bro, appreciate all of the help.
#576
Yeah, that's what I was thinking with the inside hitting the strut but like I said, I don't have my care even remotely close so I couldn't measure for myself.
#577
I have been on here for a while. The widest setup with a reasonable tire i have seen is 20x11.5 with 305. That's if you want a stock fender. You want a 12 inch wheel the fenders will have to be pulled. Also your excessive camber will look exagerrated with such a large tire. It will also get expensive burning through 305 tires. You should just keep your 11 if you don't want to stretch. I'm running 255/35 on an 11. Next setup will probably be 325/25 on 13.5. I would like a little less stretch but 335/345 are on available in 30 series.
LOL... yeah, I know about the exaggerated look, kind of what I'm going for as I rarely (if ever) see slammed cars with anything but stretched tires; and I'm not worried about lip size since they're full-faced wheels anyway.As for the tires, I'll only be driving the GS during nice weather so I'm not stressing it either way.
#578
I want to know if I could fit 18x9.5 front and rear with +34 or +20 offset without worrying about rubbing/fender work. If not should I go with 18x8.5 +35 or +20 all around.
#580
I recently bought another 2gs and have a set of LM9's that I'm thinking of throwing on there. The car is my Daily and likely won't be slammed, but lowered just above the tire. I'm not big on stretch and want to get a fairly meaty set up because the roads here suck. The wheels are 19x9.5 and 19x10 with a +30 (approximate) offset front and back. Both the front fenders and the rear quarters are rolled already. Can I fit 255/35's and 285/30's on this set up? Also, I've used Hankook Evo V12's on my last couple set ups and like the tires. How do those run....true, narrow, or wider? Any help would be appreciated. My coilovers will be ordered tomorrow and I'd like to get the tire set up locked down soon
#581
19 x 8.5 Front
19 x 9.5 Rear
19 x 8.5 Front
19 x 9.5 Rear
I'm running 19x9 +25 F (235/40/19) and 19x10 +25 R (275/35/19) and it is sitting very flush all around, I'm also on shaved rears and no mods up front.
#582
#583
I most definitely will. I'm fairly certain since the rears are fairly conservative it shouldn't be too much of an issue. The fronts, I wasn't sure how that 255/35 would fit in though. I seen Neegroy's set up and the front offsets are slightly more aggressive, but width wise we'd be the same. The 255's on a 9.5 has the look I'm kind of going for too. But, I think I would want to go lower than his fronts are. I'm going to shoot him a PM if he can't go lower because of rubbing, or if he kept that ride height strictly because of the road conditions.
#585
GS4 opinions needed on wheel and tire plans
My plans for my stock 99 GS400 are to put on 2011-2013 IS350 staggered chrome wheels. They are 5 spoke but with the low part between giving the split look. They are Front 18X8 45 offset & Rear 18X8.5 50 offset
I'm trying to keep the OEM look. MY two ideas were:
1. Front 245/40/18 & Rear 255/40/18. Negative: the O.D. is .3 inch different 25.7 front 26.0 rear. Positive: The front tire is a higher load carrying capacity in the 1600's. Original is 1521 for 16 inch 1477 for 17 inch.
2. Front 225/45/18 & Rear 255/40/18 Positive: the O.D. is identicle at 26.0 so the sidewalls should look extremely close to matched in height, which I want.
Negative: I'm nervous that the front tires load carrying capacity, that is in the 1300's being so much lower than stock and the actual width of the front tire will be less than stock, and that it is a GS with a V8 in front (heavier). I'm worried I wouldn't have good balance and to much understeer (push).
I was considering the Continental Extreme contact DW. Another size I would consider for the front would be the 235/45/18 but unfortunately they aren't made in that size.
Also planning on installing Eibach Pro Kit springs. 1 inch drop.
Ok what do you guys think? Thanks
