Wheel width/offset/size and tire fitment Q&A thread
#752
how aggressive can i go with bags and stock suspension?
K I spent 2days reading all the different sizes and I still haven't found my answer so CL pls help? lol
Im having 3piece rims made for my bagged GS. I'll be running 19's low disk. Stock suspension with airbags only. Im willing to pull my fenders as much as I need to front and back, and go with the maximum camber ill be able to get with the stock suspension.
Look I'm going for: I want to tuck the front and rear when I air out.
Whats the widest i can fit with lowest offset (how aggressive can I go)?
How big of a lip do you think ill be able to pull off?
thanks for the help.
#756
Well... if you're willing to pull the front/rears "as much as you need" and camber them as well, the sky is the limit as to what offset you'll be able to run.
What I don't understand is this: If you're already having the wheels made, shouldn't you have previously specified the offsets when you placed your order for the wheels?
#757
#758
If you're not willing to do professional bodywork then you should keep the offsets mild enough to fit with just a roll, or with camber. If you don't mind a lot of camber, then you should check out johntran's build thread, as he didn't do much fender modifications (if any) and just fit using camber. The 2GS fenders are weak to the point where almost any amount of pulling (and some rolling as well) will buckle them. Most of us have learned that the hard way.
#759
#763
Wassup guys i need help wth my wheel fitment can someone plz help me I have weds Kramer bazeria F19/9 +10 R19/11 +30 what can I do so I can go flash wth my fender and I wont rub
#765
Hey guys I have a 2gs lowered on tanabe df210s so 2" in front 1.5" in the back and i was wondering if 19x9.5+15/19x10.5+15 would fit nicely or will it stick out too much or should I just go with +22 instead. Pictures would also be helpful. Thanks in advance
