Wheel width/offset/size and tire fitment Q&A thread
Old 01-08-16, 03:27 PM
  #826
Miami-SC
Miami-SC's Avatar
Originally Posted by timherb20
I recently just bought some Varrstoen Es2 19x9.5 +22/19x10.5 +22 to put on my 99 Gs300 that has the Ls400 big brake upgrade. I know ill need to run spacers in the front to clear the caliper. They come with tires already on them 225/35 & 235/45.I just have lowering springs on at the moment(will do coil overs next).My question is will i need to roll/pull my fenders any if at all to run them on my current set up?
I'm running Varrstoen es3's in 19x9.5 F and 10.5 R both +12, with LS brakes with no spacer and there's plenty room!
Old 01-08-16, 04:22 PM
  #827
gr8bryt
gr8bryt's Avatar
I'm in a similar situation. I purchased Bremmer Kraft BR07 19x9.5 +35 all around for my 2GS w/ LS BBK. I was already running spacers in the front because I was on stock wheels. I did a test fit today and it looks like I will still need 1 of the 2 spacers that I have up front in order to clear the caliper. I have two questions:
1) Would it be wise to take the second spacer from the front and move it to the rear to give a balanced stance? If so, will I also need to get extended wheel studs for the rear?
2) Will I need any fender modifications front or rear? I'm currently on stock ride height, but Megan coils are next to come.
Old 01-09-16, 01:54 PM
  #828
Foob
Foob's Avatar
Default Opinions and knowledge requested!
I got a 1998 gs300 black on black, with stock suspension. I'm planning on ordering Lumari Kya 19 inch staggered wheels (8 in front, 9.5 in rear) with Nitto Invo 245/35/19 tires in the front and 275/30/19 in the rear. Would i need some wheel spacers to get an aggresive look im going for? I like the look of the rear wheels to be flush with the fender, maybe just a little bit of the wheel poking out. For an aggresive look without camber. Going to lower it about 1 or 1.5 inch soon afterword with coilovers. (Haven't decided on brand yet) in everyone's opinion would I get a good function and form look? Without the need to roll/shave fenders? Planning on painting the car soon as well.
Thanks in advanced!
Old 01-15-16, 08:52 PM
  #829
gr8bryt
gr8bryt's Avatar
UPDATE: I installed my wheels and they look great! I still have a little more tire sticking out in front than I do in the rear due to the spacer. I suppose question #2 has been answered, but I'm still curious about question #1. Heres a few pics of my setup
Front
Rear
Trusey22 (10-16-18)
Old 01-17-16, 07:36 PM
  #830
imjohnnyle
imjohnnyle's Avatar
Default Wheels I've been through (spec/tires/etc)
I hope these pics/info help you guys. my fronts were rolled, rears were shaved with slight pull.
WORK CR KAI ULTIMATES
19x9.5+15 (225/35)
19x10.5+12(245/35)
WEDS VISHUNUS
19x10+10(215/35)
19x11-5(225/35)
WORK EUROLINES DH
19x9+15(215/35)
19x10+12(235/35)
Old 01-20-16, 06:37 AM
  #831
plex
1UZFE/2JZGTE
plex's Avatar
18x9.5 +23
18x11 + 35
Want to fit maximum tire on rear is 285's feasible, fronts I would do 245 or 255. I'm assuming fender mods.
Old 02-22-16, 03:13 PM
  #832
PandaGS300
PandaGS300's Avatar
I am looking at getting Kranze wheels.
Size is 19x8 +19 F and 19x9.5 -15 in the rear.
What do you guys think will they fit?
Also what tire size should I get?
Old 02-25-16, 12:01 PM
  #833
OKSTANCE
OKSTANCE's Avatar
I was looking to get a very similar setup of te37 reps in 18x9.5+40 all around
im on stock suspension and brakes on my 98
you think thatd clear the front brakes/strut without a spacer??
i couldnt find anything exactly to these specs fitting on google
Old 02-25-16, 04:08 PM
  #834
firelizard
firelizard's Avatar
Not without fender mods and camber.
Depends on the fender mods and camber.
Old 02-25-16, 06:31 PM
  #835
ShunDoe
ShunDoe's Avatar
Thanks man
Old 03-01-16, 08:57 PM
  #836
Lexus777
Lexus777's Avatar
Will a 19x9.5 et -15 look normal on a stock rear of a UCF21? Or will they poke like crazy. It will not be slammed or cambered in like crazy.
Old 03-02-16, 07:39 AM
  #837
firelizard
firelizard's Avatar
1. this is the 2GS forum
2. it will look ridiculous without fender mods and or camber, and an appropriate stance
Old 03-02-16, 12:19 PM
  #838
Debonair
iModerate
Debonair's Avatar
As pointed out you are in the incorrect forum for the UCF21. You can post your question in the LS Forum HERE
Old 03-02-16, 02:55 PM
  #839
PandaGS300
PandaGS300's Avatar
When you say fender MOD do you mean a roll and pull only or more?
Old 03-02-16, 03:53 PM
  #840
PandaGS300
PandaGS300's Avatar
Front - 19x10 +20
Rear - 19x11.5 +20
Tires
235-35-19
265-30-19
Not sure if i need a fender roll only or should I get the Fenders pulled.
Any thoughts??
Quick Reply: Wheel width/offset/size and tire fitment Q&A thread
