Wheel width/offset/size and tire fitment Q&A thread
#977
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20190207_163158_da2cb28960f8063c3ec4cb239d21f4013d47890b.jpg)
Front wheel. Car resting on a jack stand on the passenger's side. Riding on stock suspension with 30mm rca and it gave me a 1 inch drop.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20190207_163145_5be8bd62c560d1f4adce2d937dd4c545d23988a6.jpg)
5mm spacer in the front to give me clearance. LS400 brake calipers were touching the rim
#978
I made a correction to my previous post. I previously guesstimated that my rears were closer to flush than they really are, but I was off by a fair amount, so my mistake. I went out and took some measurements while I was installing brand new lug nuts a moment ago. My rears are about 20mm set in from the fender. Based on that, I updated my estimates for Aeok18109 accordingly to needing a 15-20mm rear spacer in order to be flush with the fender.
#979
Hi all, I am planning to run 19x9 & 19x10.5 Vertini Drifts wheels. I want to put 245/40/19 front & 275/285 40/19 rear. I am not going for the slam or extreme camber look. Also I don't want to run stretch tires as well. Will this combo work without rubbing issues and I am just going to low it to a 1 finger gap. I see a lot of people running 35 series tires and stretch tires just for the look. I want good side wall for handling. Should I get summer or all weather tires? Thanks for you help in advance.
#981
1010tires.com & do configurations. You can get away altering the tire size. But if its not the recommended size, down the line you'll have problems. Premature wear, cupping, sidewall bubbles to name a few.
#982
#984
I've got Drag DR34's 19x8.5 on the front 19x9.5 on the rear. 265/35/19 and 285/30/19 (fat boy set up) with no rubbing. Not lowered yet but damn such a huge difference in ride and handling quality already!
#988
#989
Will this size be an issue for a 2003 GS300, especially the rear?
18x8 48 Offset front (this shouldn't be an issue)
18x9 55 Offset rear (the 55+ offset is a rather large number, one that I hardly ever see)
Note: tires are 245/40/18 all around (even though it's a staggered set up).
Thanks in advance and any wisdom coming my way is greatly appreciated.
#990
