Help HID Ballast BLOWN
Old 11-09-10 | 01:45 PM
CoolGuy660's Avatar
CoolGuy660
Default Help HID Ballast BLOWN
Hi guy, I posted this thread to see if you guys could help me out. I have an 02 GS with factory HID, my passenger side headlamp went out, took it to a shop and they said it is the ballast. They told me they can replace it but it Is a part of the headlamp assembly so they would have to order the whole headlamp.
Now of course I told them no it's ok, my question is could I just replace both ballasts with aftermarket ones with no problem using my current headlights or would I have to get non hid to install the aftermarket hid?
Old 11-09-10 | 01:47 PM
onihc's Avatar
onihc
I heart Honda
yes you can. search for hid kits with d2r bulbs.
Old 11-09-10 | 01:55 PM
Tank's Avatar
Tank
Wow, it's amazing how much people try to rip you off..lol
Old 11-09-10 | 02:03 PM
CoolGuy660's Avatar
CoolGuy660
Thank you onihc!
Yes, it's funny of auto shops have no business now. I remember driving down the same shop and it always had cars now the whole complex of shops the parking lot is empty.
Old 11-09-10 | 02:10 PM
sakataj's Avatar
sakataj
BTW this is incorrect....they are ATTACHED to the bottom of the headlight BUT they are not a part of a headlamp assembly.
just get some aftermarket ballasts and call it a day
Old 11-09-10 | 02:13 PM
onihc's Avatar
onihc
I heart Honda
a quick search pulled this up. for illustration purposes only.
http://www.omnixautosports.com/d2r-h...2r-hid-kit.htm
Old 11-09-10 | 02:43 PM
CoolGuy660's Avatar
CoolGuy660
Thank you guys, I have to make sure it is D2R correct in order to fit properly?
Old 11-23-10 | 03:13 PM
CoolGuy660's Avatar
CoolGuy660
Quick question with the aftermarket ballast?
I order a d2r set, do I cut off the connectors of the oem ballast to connect back to the car or is there a connector I buy to use to connect?
Since my car already came with factory hid what do I use to hook it back up?
The black and blue wires are the wires the kit came with thats suppose to connect to the lightbulb socket.
Attached Thumbnails Help HID Ballast BLOWN-photo-2.jpg   Help HID Ballast BLOWN-photo-3.jpg
Old 11-23-10 | 03:21 PM
Rockero28's Avatar
Rockero28
Default Hid
I have a set of Densol slims and also a set of the regular GS ballasts on some headlights I need to get rid of... I can sell you either one, or set.. Let me know in case you are still looking. I am in OC/LA.
Thanks,
Rock
Old 11-23-10 | 03:24 PM
vwynn's Avatar
vwynn
u can buy factory ballast from different car manufactures at this one retrofit place.. dammit i forgot whats it called
Old 11-23-10 | 03:26 PM
vwynn's Avatar
vwynn
http://www.theretrofitsource.com/pro...roducts_id=161
Found it... sorta
Old 11-23-10 | 03:34 PM
CoolGuy660's Avatar
CoolGuy660
Originally Posted by vwynn
So the denso will hook up to the car? plug and play?
Old 11-23-10 | 03:37 PM
CoolGuy660's Avatar
CoolGuy660
pm'ed you.....Rockero28
Old 11-23-10 | 09:14 PM
vwynn's Avatar
vwynn
i have no idea.. .haha sry
Old 11-27-10 | 02:11 PM
CoolGuy660's Avatar
CoolGuy660
Ok I've had no luck hiding an aftermarket ballast that connects right up to the oem plug to the car.
All I've found was hid kits for non-hid cars. I need a kit or wiring harness that can plug into the car harness.
Anyone care to chime in on my situation, what harness to look for? what ballast?
Quick Reply: Help HID Ballast BLOWN
