Help finding O2 Sensor Bank 1 Sensor 1 w/ pics
Old 11-09-10, 04:41 PM
bronx99
bronx99's Avatar
Default Help finding O2 Sensor Bank 1 Sensor 1 w/ pics
I've looked over all of the diagrams from other posts such as (https://www.clublexus.com/forums/gs-...n-sensors.html) but it's just confusing me more.
Can anybody tell me if the following is the correct location of the Bank 1 Sensor 1 on a 2001 GS430
I'm also thinking of just using a vice grip to take that out instead of buying the o2 sensor removing extension.. good or bad idea?
Attached Thumbnails Help finding O2 Sensor Bank 1 Sensor 1 w/ pics-2010-11-09_16-16-02_284.jpg   Help finding O2 Sensor Bank 1 Sensor 1 w/ pics-2010-11-09_16-16-36_818.jpg
Old 11-09-10, 05:21 PM
Mike813
Mike813's Avatar
i would borrow one from autozone free of charge, loosen it and hand tighten till u get home then remove. these o2's been through alot and if you strip the bolt using the grips youll end up with a bigger headache. but if you plan on just chucking them anyway then i guess you can use one.
Old 11-09-10, 05:31 PM
porn-adkt
porn-adkt's Avatar
Serious? oh boy, no offense but from the pics u posted i recommend to take your car to a mechanic or someone with a little more knowledge to help you
Old 11-09-10, 06:00 PM
systemover
systemover's Avatar
yeah thats not it
Old 11-09-10, 06:10 PM
bronx99
bronx99's Avatar
yeah i figured that wasn't it. The schematics from other posts seem to be for the gs300's and i can't find the one for the gs430. As far as i can tell.. replacing an o2 sensor is easy - i just need help finding it. Paying $200 to have someone do this which takes less than 30 minutes is a rip off.
Old 11-09-10, 06:21 PM
Agent0024
Agent0024's Avatar
Get the right tool as well as some PBlaster and it'll make the job a lot easier.
Old 11-09-10, 06:37 PM
porn-adkt
porn-adkt's Avatar
Not a rip if you do not know what to look for or what you are doing. you realize u posted a pic of a temp sensor of some sort.
The link to the thread you posted CLEARLY shows where it is.
Like i said ..Mechanic.
Old 11-09-10, 06:59 PM
bronx99
bronx99's Avatar
Thanks. But what you're telling me is like telling someone who wants to cook homemade fried rice to get it at a restaurant.
I honestly don't have the extra money to take it to a mechanic with my current living situation. Can a good samaritan take a picture of it and post it for me?
Old 11-09-10, 07:05 PM
porn-adkt
porn-adkt's Avatar
This is from the Link you posted, WTF? whats not to understand?
Old 11-09-10, 07:06 PM
porn-adkt
porn-adkt's Avatar
1UZ-FE + 3UZ-FE
Bank 1 (B1) refers to the bank that includes cylinder No. 1.
Bank 2 (B2) refers to the bank opposite bank 1.
Sensor 1 (S1) refers to the sensor that is located before the catalytic converters.
Sensor 2 (S2) refers to the sensor that is located after the catalytic converters.
Old 11-09-10, 07:17 PM
AshburnM3
AshburnM3's Avatar
bank 1 sensor 1 is on the driver side of the engine. look at the exhaust manifold and trace it until you see the first O2 sensor! if you dont know what the sensor look like and you want to do this yourself, do yourself a favor, go out and BUY an O2 sensor so you have an idea what it looks like. you need to have a O2 sensor socket or a 22mm wrench to remove it, do not use visp grip!
Old 11-09-10, 07:29 PM
toy4life86
toy4life86's Avatar
where in ca are you at?
Old 11-09-10, 08:47 PM
speedaddic
speedaddic's Avatar
jack the car up in the air, put it on jack stands, climb under the drivers side. Look up where the headers are, bank 1 sensor 1 is right at the collector of the headers BEFORE the cat. Use a 22mm wrench if you have it. You'll have to reach up high and unplug the sensor then use the 22mm wrench to remove it.
Old 11-10-10, 02:12 PM
bronx99
bronx99's Avatar
Bellflower
Old 11-10-10, 02:14 PM
bronx99
bronx99's Avatar
this is what i was looking for. makes sense since i was looking from above the engine instead of from below.
Quick Reply: Help finding O2 Sensor Bank 1 Sensor 1 w/ pics
