broke ABS/VSC sensor on suspension install, DIY threads have no more pics :(
Old 11-11-10, 04:29 PM
duckJAI
duckJAI's Avatar
Default broke ABS/VSC sensor on suspension install, DIY threads have no more pics :(
Hey guys, just swapped out my Stance coils and put back the OEM suspension for the winter and it seems like I broke the Front Left (driver side) ABS sensor. It visually still looks good so I'm assuming the wire inside broke.
I read a few posts but the links to the pictures have been taken off.
Here are the 2 threads that had pictures, but no more.
https://www.clublexus.com/forums/gs-...to-fix-it.html
https://www.clublexus.com/forums/sus...with-pics.html
If someone can post some pics for the DIY ABS sensor fix, it would be greatly appreciated!
Thanks
Old 11-11-10, 08:27 PM
lexo98
lexo98's Avatar
if I'm not mistaken it was an easy 5min job. Just jump in there.
Old 11-11-10, 09:22 PM
vwynn
vwynn's Avatar
the whole wire assembly consist of 2 wires really. just open it up and re solder them to fix the break.
Old 11-12-10, 05:58 AM
duckJAI
duckJAI's Avatar
does the break in the wire happen inside the black little box, which is connected to the end-link attached to the control arm?
Old 11-15-10, 09:31 AM
duckJAI
duckJAI's Avatar
Anyone??????
Is it the black thick wire that attaches to the hub of the front driver side? I looked and tugged it lightly and nothing seems to be broken at that point. was feeling along the lines but the rubber is so thick I couldn't feel any soft spots.
Old 11-15-10, 11:24 AM
sakataj
sakataj's Avatar
it can, but it doesn't have to. its just a wire, it can rip anywhere
Anyone??????
dude just get a meter and check the wiring for continuity
Old 11-15-10, 05:02 PM
porn-adkt
porn-adkt's Avatar
Sakataj is correct. i believe you unplug the sensor and take a meter switched to Ohm(resistance) and take a reading at the plug to the sensor. it should read between 1.6-1.75k ohms. I may be mistaken but there is a couple threads on this.
Old 11-15-10, 10:28 PM
vwynn
vwynn's Avatar
Anyone??????
u gotta cut it open to expose the 2 wires... god knows where the break is.
Old 11-15-10, 11:15 PM
Agent0024
Agent0024's Avatar
Yes, you will have to cut open the rubber insulation to get to the wires like "Vwynn" said. Mine broke right at the sensor and it was a pain to fix.
Old 11-16-10, 01:15 AM
JeffTsai
JeffTsai's Avatar
Usually if you tug on it(doing suspension, brakes, etc) and break the cable, 90% of the time the wire will be broken right at the sensor head. It's a pain to fix this because you have to cut the head of the sensor off and resolder the wires directly to it. Some guys have sent their sensors to me because they couldn't get to the wires in the head of the sensor. Just be careful if you try to repair it that you don't cut into the magnetic pickup in the sensor or else you will destroy the sensor beyond repair. They cost $220 or so from the dealer so be careful with where you cut into the head.
Old 11-16-10, 01:20 AM
TLcoats
TLcoats's Avatar
Just send it to jeff! He'll fix it for you.
Old 11-16-10, 06:31 AM
duckJAI
duckJAI's Avatar
i'll inspect it further to make sure I don't see any breaks in the wire again and take off the fender liner to make sure the plugs are good there.
I wish I could send it to Jeff, but I live in Canada. Would it be bad to drive without the ABS sensor there? Would dirt and stuff get into the sensor position and mess things within the hub?
This is what the ABS sensor looks like on the Hub right? (This isn't a GS300, just searched a random picture which happens to be an MR2) Do I need to take out the entire sensor to cut it, or just doing it from the top while the sensor is still in place ok? I don't want to ruin the sensor if it's rusted/stuck in place.
Old 11-16-10, 08:09 AM
Agent0024
Agent0024's Avatar
Take everything out. You can unplug it from behind the fender liner. Make sure that you unbolt it from the body of the car as well.
Old 11-16-10, 08:11 AM
vwynn
vwynn's Avatar
yes thats the ABS sensor.
Old 11-16-10, 11:18 AM
duckJAI
duckJAI's Avatar
Ok, so I got the entire wire out and the ABS sensor as well.
Measured it and it read 0.
So I assumed the break would be near the sensor so I cut it open near the head of the sensor (not the actual sensor, just before it. I only saw a white and black wire) and the white wire was snapped off/stretched.
Soldered it back up, no liquid electrical tape near my house so I used a glue gun as an insulator and then wrapped the outside in electrical tape.
Tested it, read 1.68-ish olms. Pretty close so good.
Put it all back together and started the car, drove it for about 5min. Lights still on.
Disconnected the battery for 20min to refresh the memory, still lights are on.
What is the problem? 2 days ago I went to my mechanic to read the code and it said LF ABS sensor faulty and no other sides put out a code.
Quick Reply: broke ABS/VSC sensor on suspension install, DIY threads have no more pics :(
