Preferred HID Kit
#31
Right.. Made me thought my bulb was bad and I bought new ones and it still does the same shiz. I don't know should I get the New Xtreme Kit (Slim Ballast) from XenonDepot or buy the cheap DDM which is 10 mins away from my house.
thats the exact issue im having john.i have found if i turn the fogs off, then turn them back on 99% of the time they both will light up. the last 1% of the time it takes me 2-3 times of doing this process to get them both lit up....my concern though is, it isnt good for the bulb to do this over and over. i dunno if its the wiring or not. the last wiring harness i bought from a seller i couldnt get it to function correctly either...
i was told by a vendor on here to try and use a ballast with a lower amp draw on startup (i dunno what mine use though) and i just wasnt feeling paying $200 for his with the 5 or 5.5 amp startup draw....specially not when the 6 amp startup is $59.38 shipped...
as i said im gonna try these out, if they dont fix my issue i didnt lose much you know. wish me luck
#32
i def have been suppporting FIGS,Sewell,Carson,PPE and a few others BUT i wasnt to thrilled about some of our vendors when i was looking for some audio stuff and didnt even get a response from anyone
https://www.clublexus.com/forums/lex...ese-items.html
#33
I really don't understand how this is an issue when our factory bulbs are rated at 55 watts. I think the main purpose of a relay harness is the initial current draw from the ballasts is better drawn from the battery instead of from the factory wiring wth it's many lines and fuses that might be an issue for a clean current draw. Also our car's wiring is old and might not be in the best condition to deliver the same current as new. Just an opinion...
#34
Former Sponsor
DDM overdrives 35W bulbs with 55W ballasts in their 55W HID kits. They actually state on their website that they use the same bulb in all their kits as they are supposedly rated to 60W. Overdriving a 35W bulb means that your bulb will burn hotter and go out significantly quicker. Whether or not their ballasts only draw 6A on start up is very questionable given the significant amount of posts I see about one side failing to ignite on occasion.
Steve
Steve
#35
what does yours draw for amps on startup? were you the vendor i was talking to for a week or so in PM bout this issue steve?
#36
Former Sponsor
Yup that was me. The Xtreme ballasts genuinely draw 4.5A on a cold start. I don't recall our conversation but I think the problem was either your HID kit or harness. Sorry... I don't remember the specifics. I just remember speaking with you given the pic in your signature :-)
#37
if these don't work, i will probably be swayed to get yours....it was just for the price i didnt
#39
i do, i have the OEM low beams, aftermarket high beams,and aftermarket fogs....but the ones im having issues with are in my fogs at startup.
you know there is a multiquote button BTW so you can respond to multiple people in one quote, just click on the + symbol and the last one you wanna quote, click on the quote button
BTW, i didnt know there was a multi-quote button or how to use it for that matter Thanks for the tip
#40
thanks, just got them in the other day....the ballasts are tiny, was preoccupied this weekend to do them and im having other electrical issues im gonna work on first as it is so these the least of my concerns right now
yeah its cool...someone had to explain it to me too
#42
i have started the car approximately 30+ times since putting the new battery in last night was the first and second time both didnt light up could have been cause it was mid 20's last night at 11. so maybe i will end up putting this kit on (when it gets warmer of course) although i dunno, if 9.9 out of 10 times it works, i might not mount them. we'll c
