i need help with wheel offset and tire size
so i have an 04 GS430 that i've lowered with Tanabe DF210 springs and i want to put 20's on it. 20x8.5 in front and 20x10 in the rear. the thing is that there is a number of offsets to choose from, and i have no idea which one to use. the front is 35, 40, 45. and the rear is 43 or 45. so which one will fit?
and then there's tire size that won't rub..... ugh!
Please help me guys.
we do,or some of us do. just want you to help your self first
BTW welcome to the club
check both these links for 99% of anything you need on here
https://www.clublexus.com/forums/gs-...ou-search.html
https://www.clublexus.com/forums/gs-...d-newbies.html
In the front u should def get 40-45 offset since the rim is 8.5 wide and its lowered.. Any lower offset will result in rubbing.. In the rear get 40-35 the rim already is 10 wide that is a lot
Well buddy it depends on what tire size your running too. But for a small stretch 8.5 +40 fronts is way too high and it will be hella sunk. I had 9 +36 in fronts before while riding low and it was minimal to no rub. Since +35 is the lowest, there will be no rubbing issues. Hope that helps..
