Differential Oil Change
Old 11-23-10, 01:19 PM
tinman
tinman's Avatar
Well, now I don't feel so bad....
I tried the jack method, no go. Finally I took it to a shop, they couldn't get it off either! They put a TON of force on that plug, and it didn't move. I could see it from the waiting area, the back of my car was bumping up and down and it still didn't come out. They tried a huge impact wrench, negative on movement. They had to torch the bolt, apply penetrating lube, torch again, and use an extractor. It finally come out. Fluid changed!
Old 11-23-10, 01:49 PM
BigSexy
BigSexy's Avatar
thats insane.....WOW Ill keep this in mind when I change mine if I cant get it off
Old 11-23-10, 02:09 PM
toy4life86
toy4life86's Avatar
no way I know mine was preety tight too but that tight is hard to believe
Old 11-23-10, 04:31 PM
tinman
tinman's Avatar
Well, to be honest, doubt of my issue wasn't the response I was anticipating. But, ok. Believe it or not, it's true. I can always scan the receipt.
Old 11-23-10, 04:52 PM
D-Boi
D-Boi's Avatar
is all this headache really worth the 20 bucks a shop will charge you to do it for you? Especially if you have your own fluid.
Old 11-24-10, 07:55 AM
tinman
tinman's Avatar
Clearly, no. But it's hard to know that it's going to be this much a problem BEFORE you start the project. If I had known this was going to be an issue, I would have had them take care of it 2 weeks ago. It was hard to know that 2 weeks ago, however.
willfxp
03-16-11 03:51 PM
horny300
CL of Southern California
14
06-07-08 02:59 AM
1genls400
04-10-08 11:26 AM
tdandkd
RX - 1st Gen (1999-2003)
04-06-08 07:53 PM
masboy
23
01-30-08 12:43 AM
Quick Reply: Differential Oil Change
