Constant Dash noise like chirping, kissing, squeaking
Very common problem. Check this thread. https://www.clublexus.com/forums/gs-...ete-guide.html
From experience, rebuilding/repairing your old stuff works for a while, then they fail again, usually within a year. Find which one is the culprit and then find online. Isolate by listening while you do things like switch the air temp from hot to cold (each side independently), or switch from inside air to outside, etc.
