Timing Belt Question?
I'm in College so my budget is kind of tight. Anyways, I am looking on getting my Timing Belt Replaced soon. I have heard that many replace the Thermostat while they are having their belt done. However, I was wondering if anyone has actually had the Thermostat fail or need replacement? Without the thermostat I'm looking at the following labor:
Timing Belt Job
Water Pump Job
Crank Seals
Cam Seals
Dry Belt
So is the thermostat necessary?
Timing Belt Job
Water Pump Job
Crank Seals
Cam Seals
Dry Belt
let me put it this way....DO the thermostat at the same time since your not doing all your own work it will be cheaper with it all torn down. wouldnt u hate to have a freshly rebuilt car and the thermostat fails and you gotta pay labor AGAIN on this?
i did mine with my 90k service.....never thought bout it again till right now
im in college n i was able to afford all the things for timing belt... included all pulleys, seals, etc etc n what not.. EVERYTHING for the front end really... Dont cheap out.. no excuses. IMO. if you want your car to last take good care of it.. you cheap out on it it cheaps out on you.
Take good care of your car and itll take good care of you.
You really dont need to get the cam/crank seals replaced. When i was talking with both my lexus mechanic as well as the mechanic at toyota (the tundra has the same v8 as the gs400) they both said they have never heard of the seals going on the v8. They go often on the gs300 but not on the 1uz. 141k miles and i have to agree with them, seals are bone dry.
