Memory seats
Memory seats
So for some reason, my switch is not working.. I was wondering if there might be a fuse somewhere, or might I be looking at a bigger issue, in which case, I would be forced to say buy to this option... Since it's not that important./
Thanks,
Rock
Thanks,
Rock
Your seats are fine, its the way of setting them up thats weird. I thought mine were bad as well until i figured out how to set it up.
http://us.lexusownersclub.com/forums...howtopic=46508
i know this sounds silly rockero...but have you had any work done inside the door panels lately even some you did?
i ask because one day i took mine off and then a few days later i noticed my seat memory wasnt working. it slowly dawned on me that i didnt plug the switch back up...yes stupid i know but least i realized it and it was free
if not the issue, make sure the key is turned forward, car is in park and i think your foot off the brake. do you hear a beep of any sorts? yes there is a fuse, i think but dont quote me its fuse 31 or something....check your owners manual
BTW since its very similar im sure it doesnt matter much but that link is for a SC not a gs
i see from another post you said you had a door actuator installed, take a minute to verify that it got hooked back up since it stopped working right after you had the door panel off already
BTW SEARCHING INSTEAD OF MAKING A NEW POST
Seats
Thanks,
Rock
good luck hopefully your is just plugging it back up and not buying a new part
