HELP!! P1349 Code-1998 Lexus GS300
I own a 1998 Lexus GS300, and recently the Check Engine Light, VSC, and VSC OFF lights came on. An diagnostic scan showed a P1349 code. I checked the oil control valve screen and it was completely clean and unclogged. I also put 12 volts of power directly to the camshaft timing oil control valve and it appears to be functioning properly. Any other ideas as to what could be causing this problem? Thanks!
lildorsey1
05-13-15 01:47 PM
