ABS and brake light on. help.
1999 gs300. so i start my car and try to roll down my windows.. windows dont work. then i realize ABS and brake light on dash is on and i cant get out of gear from park. so i check some fuses and everything is ok. brake lights work. brake fluid ok. ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
later on in the day i check again and all problems are gone.
what could be the issue???
any help appreciated. thanks.
i just replaced the alternator a few months ago actually.
ive searched around the forums, but i dont think ive found a true solution. and the real odd thing was the windows not goin down. i checked fuses and everything checks out.. i just dont want this same thing to happen to me when im not home and create a huge hassle.
no its just the brake and abs light.. when everything was ok, i was driving around for a few days with no problems.. and then the vsc vsc off lights came on.. got home, restarted the car and then the brake and abs lights came back on.
Had a similar problem like this. Is there a eternal warning beep with the ABS and brake light? Mine had that for about 30 minutes. Than it went away. Then my entire master cylinder failed and I had no braking power. After replacing the master cylinder it went away.
lottadik
05-17-19 12:07 PM
TedFury
08-19-13 07:22 AM
