Where is fuse for cig. lighter?
Where can I find the fuse on my gen1 for the cig. lighter? I think the fuse must be blown because my radar detector stopped working and I tried something else in the lighter and that didn't work either. So I am guessing it is the fuse... Thanks!
Chicago Lexus Club Moderator
check your drivers side kick panel.....i'm pretty sure that's where its at....look on the fuse box cover for CIG and that will tell you which fuse it is....
Hey Mcnelson. it is under the kick panel. right above the foot break. if i remember you might have to remove a screw or 2 to get to it. or just unhook it somehow. forsure its there cause i check mine. my fuse is good but my cigarette outlet still don't work. if you find out whats wrong please tell me it might be the same problem with my car. thanks
Originally posted by Jmai22
did you ever fix it??
its soo freaking annoying huh??? try charging your cell phone from the back and using the phone. at the same time. its like pulling down on it. and the wire keeps getting stuck between the freakin chair. if you even find out please PM me or something i'll do same for you. THANKS
have you tried maybe pulling the lighter out and making sure you have a good connection? Check with a test light to see if you have 12v going to the lighter.....it could be something other than a fuse.....also check in your fuse box under the hood to check if there is a separate fuse out there.
