LS430 Quad HID Projector Retrofit - w/ Progress Pics
#31
I totally get what your saying, and it's a very good idea. Thanks for sharing, it is defiantly some info I will be pondering on.. And it is the way I thought you meant, which does eliminate the original mounting method this projector was meant to use.
Thanks for the visual aid, it does help..
And previously you said the Bi-Xenon you tried was too large for the housing. The e46 is a 3" Lens, that's a huge projector to fit in such a small space. What's you status with this? You still trying to make it work?
I had the e46 shrouds cut perfectly as well... would have looked nice
#34
I thought about doing that, but I've removed the solenoid and flip shields from the bi-xenon and it is going to function only as a high beam.
Now you got me second guessing my decision a little.
#35
Awesome write up 99 GS3. I'm looking to do exactly what you were planning. LS430 low beam with bi-xenon high beam projectors that turn on with the low beam. I'm wondering if you can tell me what projectors you put in the high beams, how you mounted them, and if you could tell me a little bit more about how they're wired up? picture of how they were mounted would be amazing since like you said in the thread having them mounted off center doesn't look that good.
Also I read somewhere on another thread that running 2 sets of 35 watt ballasts on the low beam would fry the harness. Can anyone comment on that?
NemeGuero
General Classifieds
05-30-10 08:08 PM
