Crank but wouldn't start - Help!
Old 12-09-10, 09:08 AM
blue99GS4
blue99GS4's Avatar
Default Crank but wouldn't start - Help!
All,
The car is a 99 GS400. The battery is new. Starter was replaced not long ago. This morning, it wouldn't start. The motor would crank. The battery feels strong. The engine just wouldn't start. Any idea is appreciated.
Thanks
Old 12-09-10, 09:24 AM
FrankT
FrankT's Avatar
Simple stuff first
Check your fuses...
Check the dash lights and make sure you have a check engine light , if no check engine light when the key is turned to on then the fuel injection system, more specifically the ECU is not powered. This may indicate a blown ECU fuse.
Check for spark then fuel pressure...
good luck.
Old 12-09-10, 09:33 AM
LiCelsior
Retired
LiCelsior's Avatar
battery terminals tight?
Old 12-09-10, 09:51 AM
blue99GS4
blue99GS4's Avatar
All,
I noticed my positive terminal was a little loose so I tightened it. Then I just for good measure, I had my neighbor to jump the car for me. Same thing, it cranks but wouldn't start.
Old 12-09-10, 10:28 AM
LiCelsior
Retired
LiCelsior's Avatar
check fuses and u smell any gas?
Old 12-09-10, 10:47 AM
blue99GS4
blue99GS4's Avatar
I don't smell any gas. I'm checking the fuses...
Old 12-09-10, 07:27 PM
AshburnM3
AshburnM3's Avatar
scan it for code, check your fuel pump
Old 12-09-10, 07:43 PM
Bigxdaddy
Bigxdaddy's Avatar
with mine i had to hold the gas to get the car to start if i didnt it would keep cranking. check the throttle body, i had to get mine replaced. i also had to get my fuelpump replaced
Old 12-09-10, 07:55 PM
gsjason300
gsjason300's Avatar
Prolly coil or ignitor? Or fuel pump, u got gas? Lol =x
Old 12-09-10, 10:01 PM
toy4life86
toy4life86's Avatar
try another key if you got one
Old 12-09-10, 10:05 PM
pitmanr200
pitmanr200's Avatar
Mine did same thing. I bet its fuel pump. Take off a access panel under back seat. Turn ignition to on position. You should hear a click noise on drivers side back seat and then a humming noise. If u don't please read thread a while back from me on my diagnoses of mine. Great info and help there
ok98es300
03-30-11 07:32 AM
miraluna
Performance & Maintenance
14
10-28-10 09:18 PM
cire626
10-08-09 06:07 PM
MR2-Mike
01-18-09 10:32 PM
black_LS
03-03-08 05:20 AM
Quick Reply: Crank but wouldn't start - Help!
