gs400 no overdrive????
Im at 3k at 80, and i just changed the coolant temp sending unit to see if the comp was thinking that the car wasnt warmed up, i pullled the ecu-b1 fuse and it seemed too reset everything, after this im not sure what else i can do besided replace the ecu, its locking up, def. in 5th gear, seems like it has different rear gears. When i bought the car saturday, it did have slotted and drilled rotors all around,which makes me wonder who does that to a lexus? someone who was trying to go real fast i guess.
Ok, so i just went to a lone highway and did a 0-cut off run. It is a complete monster to 120 or so, then it cuts off. The speed limiter is engaged at 120 or so in 5th gear at around 5200 rpm. Now im at a complete loss. 60mph is around 2400rpm, 80 is 3200rpm or so. I have complete lock-up of torque conveter, and i can shift from 4th, which is 33000rpm at 60-65mph. WTF????
Oh, and i should say that when hammered from a stop, it spins for about 10 feet, then converter locks up after 3k or so, then it just ignites the tires to the point that traction control kicks in till 2nd gear. I think this was a road racing car, cause it is faster than my 2001 SS to 120mph. DAMN!! i think i bought someones racecar! not what i wanted to do!
If torque converter locks at about 3k, it have a aftermarket high stall torque converter.
what tires and sizes you using?
seems like you have a different rear end, got LSD?
IIRC 98 GS4 doesn't cut off at 120... I did 130+
Yeah, your car's last owner did quite a few things to it I suspect.
you know any mods on the car? pix?
If your car is in fact around 3000rpms at 80mph AND you are definitely shifting into 5th gear then without a doubt you DO HAVE the 3.73 gearing (up from the stock 3.26 gearing).
Also, if it seems like your car is very aggressive off the line and you "feel" a converter lock-up around 3000rpms then you also have a high stall torque converter. If you search these forums you will find that this is a pretty common pair of mods...expensive, but many do it that don't intend on going forced induction; it REALLY wakes the car up!
One suggestion...the previous owner SHOULD have a standalone transmission cooler (looks like a little radiator) if you do have a high stall torque converter. That TC REALLY heats up the tranny fluid and the #1 reason why trannys fail is due to excessive heat. Check your car out up front by the radiator...perhaps you have a little tranny cooler up there as well. If you don't get one ASAP as people have had many problems down the line with the mods you have WITHOUT running a tranny cooler. FYI, the tranny coolers are only about $60 bucks or so. B&M makes nice ones...that's what I got. GL
So the first thing i need to do is get a tranny cooler if it doesnt have one then, Im pretty satisfied that the guy modded the heck outta it, as far as tire size, I think its the 225/65/16 or whatever the car came with stock. as far as looks, it looks just like a black 98 gs400. If the guy would have just told me that he did that too the car i would have been fine with it, just would have been nice to know about it instead of me flipping out thinking something is wrong.
Pearlpower
05-23-06 09:52 PM
