18x8.5 + 40
Old 01-05-11, 07:25 AM
1QWKGS4
1QWKGS4's Avatar
Originally Posted by j stuff
They are going to be more sunken in than the OEM 17 inch wheels for our car...
What you said is actually incorrect, the more lower the number - the more out you go.. Stock is +50, so if you are +40 you're 10mm more out plus the .5" more than stock (8 inches) which translate to about another 12.7 mm so in total you're pushed out toward the fender 22.7 (a notch under half an inch).
The numbers are confusing less is more.. Usually sitting Flush you will probably want +30 to +35 on 8.5 inch wide.. if you are 8 inch wide probably +25 to +30..
I know, i'm actually running this exact setup, I have 18 x 8.5 +40 and its very close to flush in the front but rear needs 9.5 wide w/ +40, and that is how i like to roll and for the record its not really that sunken in because the wider rims 8.5, if it was 8 inches or less wide then yes Sunken for sure..
skibumm3
08-19-23 03:46 PM
Rividsoul
10-31-08 09:48 AM
zajac
09-11-08 09:35 PM
ChronoJ1
Wheels, Tires & Brakes Forum
12-28-06 12:46 PM
realtourgs
Suspension and Brakes
09-06-01 05:17 PM
Quick Reply: 18x8.5 + 40
