Parking lights wont turn off
After the last rain ( I didn't move my car(it was parked)....)I didn't submerge it in water........ my inner headlight bulbs (parking lights) wont turn off.
My LED tails are also on?
Any ideas on what it may be?
They just turn on by themselves =/ Even if I double lock and they are off about 30 seconds later they turn on by themselves ?
wow. this is a serious problem.
mostly likely it's your relay.
DID you mess around with the light wire or add straight on the wire without adding fuse?
really serious..
I messed around my old 2000 coupe accord lights. add more lights by connect straight taped on the OEM wires with our adding more fuse. Later in time, my fuses got melted. and the relay gone crazy.
My interior lights and parking lights turned on. my alarm turned on automatic.
shorten the story. MY car went crazy because of the electrical problems. so I said to myself i wont mess around the lightning systems. "Dont mess around with ur fuses and relays system". with a small mistake. u will make your car gone crazy.
. I CHANGED THE WHOLE ENTIRE FUSE BOX SYSTEM WHICH GOT MELTED. AND OTHER WIRES MELTED OUT"
really serious..
http://www.youtube.com/watch?v=BSW19Kub24o
The parking lights are off....(But the car leaves them on)....
Then when I put my emergency flashers on it does this....
As i experienced. This is the cause of crazy "relay"
it wont let you turn off unless you take out the fuse for parking city light. Test it. Unplug and plug in.
Try to listen when your relay "sound" . If there is a sound it will sound like a "click".
Try to open the biggest fuse box. And behind the box cover. It will tell you which one is for parking light, head light, fog light, interior light....ect.....
In the testing process( you have to turn on all the lights on) and try to unplug and plug back. To test which one is the one you looking for)
hope this will helpful to you
tail relay, drivers side kick panel, right next to the FOG relay.
* I woud remove the relay, check the legs of the relay 3 and 5 and make sure they are not stuck closed.
* Also check if u are getting ground at 2 on the socket. If you are, that is causing the relay to trigger and lighting up the tails.
