wow i have never seen that one before? i know trd has another style grill, but i have no clue as to which one that is? good luck, did you buy it, where did you see it? i would loose the "L" logo for sure though.
Any pics on the car.. Where r photoshop people at? Interesting grill
well as stated above... that would be me.
Ok, I just attempted to photoshop this and I'm convinced that this is not for the GS. after resizing to fit my GS model, the proportions were incorrect. This grill is much wider than the GS. I want to say that it may be for the ES.
Interesting. Certainly advertised as a GS300 grill down under. Will check dimensions and fit etc when I go and see it. Will take the trusty camera and post what I find.
Cheers
Where do you see it advertised? Heres a pic of the grille next to the GS grille and you can see the length to with difference. And if I bring down the size to get the length the same, it makes it to 'thin' from top to bottom. But then again, could be an angle problem
or now that I think of it, it could be for the 3GS
Thanks for this. It would have certainly been something totally different! Bear in mind however that the grill in the original pic was leaning against a brick wall, and angled backwards.
Could I trouble you to do one more pic please - with the new grill covering the original. It would be interesting to see what it could look like.
Ok, nothing special, done quickly. I have one with it on the 2GS that I had to stretch and skew to fit. Then I have one of the 3GS which fit perfectly:
