Weird HVAC problem. Drivers side blows cold only. Not servos or doors.
im gonna bite my words damian....the bolded is true. i had this issue and after rechecking my servos, i put my gauges on and i was indeed low. im still curious by this as this is a closed system and if one side is cooling (since the car only has one condensor) then the other side should be cooling also, but it wasnt....i put the gauges on and it was low, recharged her and all is good again but i will keep a eye on it. if it went low from 5 years ago (when i last put some R414B in it) i seem to have a uber small leak (or i hope thats the case) and may end up using some cliplight to "seal" it if it persists
LVLarry
GX - 1st Gen (2003-2009)
15
02-19-08 04:37 PM
