spoiler delete (warning light)
I did a search, wasnt satisfied with the results. Spoiler does not work at all for the lighting, how do I wire it so that it doesnt trip the indicator on the dash? Can I simply disconnect it or do I need to solder it together? Thanks.
I had the same problem, i posted a thread about the same problem not too long ago, and what I found was this place called spoilerlights.com ,, these guys have the right stuff, measure up the length of the LED and find ur match, it bolted right up and best part about it was that I didnt remove the spoiler, unless you also dont like the way it looks, then remove it i guess
