I'm Sick Of Steering Feel!
Your alignment specs can make a difference in steering feel.
http://www.niumotorsports.com/formul...suspension.pdf
I tend to deviate a bit from the Lexus factory settings and let my alignment guy dial in the ideal setting for better steering feel & handeling since my suspension is no longer factory. My steering is much more improved.. If you were near me, I would let you test drive my Lexus to compare.
You will find that folks that track there cars constantly align their cars to tackle certain tracks and conditions.
Try the alignment route instead of spending hundreds of dollars for decorations under the car that will not improve the feel of the car.
Engineers design small
amounts of positive or negative camber
into vehicle suspensions to aid handling
and steering.
and steering.
Tim you will spend a year looking for a l-tuned ecu. as long as i have been on here i think i have seen ONE for sale. when i bought my car i spent the better part of a month searching for one and couldnt find one ONLY to find out that the GS430 steering ecu is essentially the same as the L-TUNED steering ecu so it might just be easier for you to find a gs430 steering ecu
Actually, its not since now I have Both cars I can confirm that the GS430 Steering Ecu is NOT the L-tuned ECU.. I have the L-tuned on my GS400 and its alot tighter than my GS430.. I thought the same as everyone until i was able to have both cars side-by-side for comparison..
Sorry Brian, but I know i everyone with numerous post says that the GS430 Steering ECU is the same as the L-Tune ECU..
The other thing to look into is tightening the steering pre-tensioner if you haven't already done this.
https://www.clublexus.com/forums/gs-...-searched.html
+1. Bitkahuna did a back-to-back test somewhere back in 2001 as well. The GS430 ECU might be a step in the right direction and certainly will be easier to find.
My GS handles wicked. I have a lot of aftermarket bracing though.
here is what i suggest, they made the biggest difference for me.
If you want it to handle like a sports car you need:
-Stiffer springs (16K,12K) on a good damper
-Sway bars (i suggest Daizen, TRD's are way too stiff)
-Rear subframe to body braces
-Rear crossmember brace
-Adjust your steering pre-tensioner
Most important...alignment
Thanks for the input guys! I'm now looking for a set of TRD sways to help stiffen up the body roll and if an L tuned ECU pops up in the classifieds i'll pick it up. Unless Brian jumps in before me.
I haven't done this yet. I just don't get the DIY. You're suppose to put a bolt with a nut into the other bigger hex bolt? Theres nothing there that could do that except by drilling a hole. I think this will help me alot too, my steering feels really loose and my bushings are pretty much shot.
As far as the stiffer springs, i have 12k/10k right now. Could i just buy 16k springs for the front, then move the 12k's to the back? Or would my dampening not be able to compensate?
Rear subframe to body braces. Are those like a Tom's 6 links?
I'm definitely going to get a Rear Crossmember brace, but after i get Sways and the other bigger improvements.
TRD are too stiff? I didn't think that was possible. I've ready many many threads on the Daizen vs. TRD debate and everyone that got Daizen then TRD's couldn't be happier. Remember, i like stiff.
Not like the Toms 6 link.
I have separate braces on mine.
You get those from Ultra Racing?
http://cgi.ebay.com/ebaymotors/ULTRA...ht_14188wt_915
Did they make some improvements?
I did a review of my Upgrades back in '03 - Check out #3 Where i did a Daizens vs. TRD Comparo -- https://www.clublexus.com/forums/gs-...-this-1st.html
Enjoy!
Enjoy!
It's all about preference. I personally like having the lighter steering wheel, but some may like it heavy. I say it's worth a shot since it's free an can be easily reversed within a matter of seconds.
Your right Dave, Stock-for-Stock The GS430 Steering ECU is I say a little bit firmer with less play than my GS400 with its Stock Steering ECU - buy now that I have both cars i can definitely confirm although the GS430 is tighter than the GS400, The GS430's Steering ECU is not the L-tuned Steering ECU - Its maybe at best 30% of the real L-tuned ECU..
hmm well ty don for the info, i was going from my memory and from my old research and from everyone telling me they were they the same....maybe its cause you cant find the l-tuned steering ecu? how does the l-tuned/gs430 compare to the sport design steering ecu as this maybe another option for tim? BTW tim i might have found a company who has them, i just emailed them and if they have them i will pass on the info
on a side note don IF i come to import alliance i would love (if you dont mind) to test drive your gs400 to compare it myself to the steering in gs430. not cause i dont believe you but to give myself a bigger reason to hunt down and buy a l-tuned ecu
if one pops up tim i will probably be the first person on it but dont hold your breath....search L-tuned steering ecu in the classifieds and see what you get. look how many people made WTB threads
I didn't buy them off Ebay though, i got them directly from Ultra Racing
You can always modify the steering wheel itself. I drove a GS430 with everything tightened up and it was real smooth, and everything was in control. Big difference in the way it felt and the way it handled.
