will a soarer pumpkin jzz30 fit a gs400?
Don't take this for cash because I haven't tryed it yet, but it should swap. From what I could find on the net, GS300/400 uses the same diff size as the MKIV supra and the MKIV has the same drivetrain and suspension as the Soarer.
The diffs found on MKIV Supra's are Torsen LSD. IIRC the one on Soarers/Sc300 are open. Gearing is 4.30 on all N/A MKIV and on the Turbo version you have a 3.78 with AT and 3.23 with 6 speed manual. You can also swap your gear on the pumpkin.
This will be my first modification on the GS.
Why are you bothering? LSD or shorter gear ratio?
From all the picture I could find and from P/N on lexuspartsnow and ******* they are all the same except for the TT Supra
Here some info I found on the net:http://alscforum.com/discus/messages...tml?1178075163
Apparently TT Supra diff is different, but the rest is exacly the same as a MKIV
More reading: https://www.clublexus.com/forums/gs-...0-pumpkin.html
