Help Please!! Gear
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Okay. I was going to replace the gear indicator bulb, and instead of pulling the bulb out and replacing it. I turned and twisted the bulb housing which made it fall inside the gear housing. So I unscrewed the two bolts to get inside the gear housing, and now I can not get the spring (that releases the gear) back into place. Now the middle of my car is in parts because I can not put it back together, can someone please help? PLEASE!
man wish i could help you, i haven't opened that up before but here's a bump so maybe someone else can chime in..
Funny thing is, i did the same thing, i felt dumb not just pulling the bulb out for some reason i twisted that base and it fell in, i was able to get it back into place without taking everything apart though..
Okay, I got it all fixed, bulb changed, and everything back together. I was in a dang panic, but I settled down and got'r done. Thanks! Mods this can be closed if you wish.
FullTimeX2
03-05-19 10:39 AM
